Heat/AC Fan and window Problem
Old Oct 28, 2007 | 10:52 PM
GRNMSTR's Avatar
GRNMSTR
I have a 04' F150 4x4 XLT with Manual Heat/AC control. The problem that I am having is that the Fan will only run on settings 3 and 4. The Fan will not blow a bit of air on setting 1 or 2. I have checks fuses but there is only 1 fuse that supplies the power for the unit. Any Ideas? This truck now has 132k miles on it. I also have lost power via the passanger side power window (will nork via master driverside control but not from passanger side, even tried switch from back door on passanger side), I verified that the window lock feature is off but the passanger side front door window will not function.
Old Oct 29, 2007 | 10:36 AM
Wilber15's Avatar
Wilber15
Blower motor resistor....
ZachFean
22
Nov 25, 2013 12:35 PM
monsum
Oct 2, 2012 09:11 AM
Prozon
1997 - 2003 F150
Jan 8, 2010 03:41 PM
privatedog
Aerostar
Dec 8, 2004 10:34 PM
WRKNMAN68
1997 - 2003 F150
Sep 29, 2004 11:33 PM
