1993 F350 351W 5.8L XLT Major Electrical Issue-FIXED
Let me first say hello and I am proud to now be apart of this forum!
(EDIT)
My problem was yes a grounding issue. After about five hours of more wrenching I found out that there was an issue with the power window ground. Because after creating my own grown as a control to the problem. Thanks for the help!
My problem with my F350 is yesterday while driving down the road I had my:
-Lights
-Heat
-Dashboard Lights
(All On)
-And was in the process of rolling down my window
When all of a sudden my dashboard lights immediately died. Leaving me with my power window stuck down. As well as my heat cut off.
The strange part about the entire situation is now when my ignition is on the blinker notification lights as well as the high beam are stuck on. As well as the interior light. BUT they seem to be at a solid 30% what they would be at if full power was actually going to them. But when you actually turn these accessories on they go back to 100% power and work. Except for the windows, dash light, and heat/ac.
But the blinker, brakes, and high beams work perfectly well. The truck starts fine and runs just like it has. It only has 50,000 miles on it if I may add.
I have spent the entire day checking every possible fuse, swapping them out for new ones. I took booth doors apart trying to fix the power window to at least get the window up to save it from rain. I had even went so far to try and jump the window with 12v to make it go up.
But something is absolutely wrong. When I turn the heat (does not work) to 1,2,3,4 power levels the blinker lights and interior light almost seem to gain 5% increments of power for each level. This is simply insane. This all happened by just pressing the button for the window to go down.
Please let me know what any of you think. Thanks!
(EDIT)
-Lights
-Heat
-Dashboard Lights
(All On)
Like JWC3 said originally, and as I tagged on to repeat, this sounds a lot like a grounding issue. Normally, current comes from the battery through the load, to the chassis or body, then back to the battery through its connection to the chassis or body. With everything failing all at once like that, and with it being multiple independent systems failing, it seems that you lost a ground that is common to all of them. The ones I called out are low-hanging fruit, as it were; also, they are common to the failed systems.
It almost seems like these things at 30% are stealing a ground from something else, thus corrupting the entire system. There were no tears or cuts in any of the door wiring or window controls as well. And when trying to jump the window motor there would just be an ark of power jumping off it. Instead of it actually functioning.
Those items utilize multiple ground points, fender near bat and behind drivers side kick panel name couple for example. They do share a common power circuit though.
Check fuse "P" under hood power distribution box.
If fuse "P" is good quick test, do those items work when the key is turned to the "Accessory" position?
If so ignition switch is highly suspect but might be damaged circuit between switch and fuse position 14 under dash fuse box (fuse 14 should be a CB by the way) Blk-lt grn wire run between the two.
