Help 10K mod? HUGE QUESTION
Old Oct 28, 2007 | 09:37 PM
MallardSlayer07's Avatar
MallardSlayer07
My Grandad has a 2000 model psd 7.3L! Can i do the same 10 16 18 20K mod on his truck because i think i found the same plug that our 97's use. Also am i going to blow out the fuel pump or harm anything with a 20k mod! Hopefully you will reply coon. Thanks for any input!
Old Oct 28, 2007 | 10:15 PM
Talyn's Avatar
Talyn
theoretically to me atleast, if the 7.3 pcm in the 2000 is the same as the OBS, then the mod should work just fine.
Dont take my word for it. Coon will know probably. =)
Old Oct 29, 2007 | 08:04 AM
tjbeggs's Avatar
tjbeggs
Yes you can do the same mod to any 7.3 PSD. 94.5 to 03 are pretty much all the same with a few changes. but they are all operate the same. Wire color might be different though
Old Oct 29, 2007 | 03:47 PM
MallardSlayer07
ok tj so will the mod hurt my truck if i run around on the 20 all the time or am i asking to drop my fuel pump?
Old Oct 29, 2007 | 03:54 PM
tjbeggs's Avatar
tjbeggs
Won't hurt the fuel pump but unless he has a pyrometer nobody has reported on EGT's yet. so it may run the exhaust temps up too high. More than likely it won't but it still unknown as far I've heard.
Old Oct 29, 2007 | 07:46 PM
c00nhunterjoe's Avatar
c00nhunterjoe
connector is identical, color is different but the same position. crank it up, odds are it wont take much over the 20k either. even though it has a bigger hpop the split shot injectors demand lots more oil. still recomend gauges.
