I'm ashamed to say, but one was a 3.0 and the other was a 2.6. I completely blew the tires away on the line. Since this was only my second time on a drag strip, and there was about a bajillion people there racing, I didn't stop to use my mind. If I had, I would have dropped the rear tire psi to about 40 or 35 in all 4 rears. I didn't stop to think, "80psi in all 4 rears" DOH!!!! At least I beat my best friends dodge both times. He would pull 3 truck lengths on me on the start. I passed him at half track both times. Man I love nitrous!!!
i doubt that nitrous is doing much... are you blowin any smoke at WOT once the turbos are spooled up without it??
No, it doesn't do alot at this point. I believe it only netted me like 40hp on the dyno. It does blow smoke on the top end, not alot, but some. But like cOOn said, you need alot of fuel to really make the nitrous do what it does. And with stage 1's, I'm not really taking advantage of it's potential. But I still stand by the fact that I love the crap!
my 1/4 mile time is from 18-20 seconds (so says my edge) depending on how good I can shift. 3 inch strait pipes, K&N intake and an edge evo downloader. hoping too have an intercooler and bigger injectors by next spring. it's a 1994 F-250 extended cab, 4X4.
hey 2 stroke man, before i got my injectors, i ran a 17.3 with my superchip, dp, intake and no cat with a messed up tranny. you should be in 17's. good luck man
