Sponsored by: Kumho
Front Spindles
Old Oct 28, 2007 | 07:46 PM
SKS45's Avatar
SKS45
Question Front Spindles
Hi Guys,
Could use some suggestions here. The dust shields on my 94 F140 SC with 4WD are rotted out. The left side is so bad that a portion of it folded up and was rubbing on the back of the rotor. Coincidently, the brake caliper on that wheel hung up the same day as well. So I've ordered new dust shields from Broncograveyard and have been trying to get the old ones off. I'm only working on the left side now so that I've got the right side to refer to when I put the manual locking hubs back together. In any event, spent a day wrestling with the Spindle nuts as the spindle must come off to get the shields out. Finally got the nuts off this afternoon after breaking a craftsman socket. They were pretty corroded and had a lot of brake dust caked on them. It was like concrete. In any event, I'm about ready to stand up and do a jig and guess what. The spindle is rusted on. I've doused it in PB blaster now and am letting it sit. Tried a couple of whacks with a rubber mallet but no joy. So tomorrow I'm going to see if I can get a drum puller to grab it and pull it off. The other option is to try and drive a screwdriver or chisel in between the spindle and the "knuckle". Anybody got any other ideas?
Brett
Old Oct 28, 2007 | 11:36 PM
75F350's Avatar
75F350
Little heat and a "Spindle Puller". The right tool is nice to have in the box, but if you don't want to spring for one, just rent it from your local rental place. Heak I am sure you can find something to buy from a local parts store that will loan you a tool.
Don't try to wedge a screwdriver or chisel behind the spindle, you will not do anything other than ruin the spindle and the knuckle, by messing up the two surfaces where they meet, and you will end up buying all new parts, that would be a real bummer.
Old Oct 28, 2007 | 11:40 PM
75F350's Avatar
75F350
double post, don't know how that happened.
Old Oct 29, 2007 | 04:43 AM
SKS45's Avatar
SKS45
Wink
Thanks 75, I'll look into getting one to add to the "collection".
Brett
Old Oct 31, 2007 | 03:48 PM
ynevada's Avatar
ynevada
put the spindle nuts back on(both) hit them with the hammer. not a rubber mallet.
ORR.. use a brass hammer, and hit IN BETWEEN the bearing surface.
first on top, then on the bottom. once theres a tiny bit of room..slide a thin blade driver in, and hit it from the opposite side.
Old Nov 1, 2007 | 05:50 AM
SKS45's Avatar
SKS45
Thanks ynevada. I went to auto zone and got the puller attachment for 25.00. Was going to try it last night but the ghouls and goblins wouldn't leave me in peace. Hopefully tonight.
Brett
xaviar
May 23, 2016 10:52 AM
70torino429
Jul 27, 2015 05:51 PM
BroncoBilt
1978 - 1996 Big Bronco
13
Nov 13, 2014 06:35 PM
Blue and White
Sep 28, 2013 04:59 PM
Burple
Sep 27, 2007 07:20 PM
