Sponsored by: Auxito
Hard to start when cold
Old Oct 28, 2007 | 09:48 AM
akita's Avatar
akita
I've 2000 F-150 4X4 S/C 5.4L 7700 (300,000 km) It runs very nice, bad on gas (combined city/hwy 13 mpg). Every morning I've really to put starter to work, it start & dies over & over!!!! But I don't have any starting problem when the the temp is worm. The check engine lite came on 2 weeks ago & reads PL4151, could canister control valve effect cold start?
Thanks !!
Old Oct 29, 2007 | 11:23 AM
KingRanchMan02's Avatar
KingRanchMan02
If you hold the gas pedal down a little when you crank the engine over, does it start easier? If so, then I would suspect a bad IAC valve.
I don't know that the EVAP system would cause the truck to be hard to start. Some other more knowledgeable FTE users will be along soon to help out. Good luck!
Old Oct 29, 2007 | 12:22 PM
projectSHO89's Avatar
projectSHO89
"PL4151" is NOT a valid fault code.
KRM is probably on track suspecting the IAC. It's a really common failure item.
Also, if you're running high octane fuel, it can also cause hard starts due to its lower volatility.
Steve
Old Oct 30, 2007 | 08:23 AM
LastSplash's Avatar
LastSplash
I had the same problem with my 97 until I pulled the throttle body and IAC cleaned them both out.
Old Oct 30, 2007 | 10:53 AM
akita's Avatar
akita
Thanks and sorry the code is P1451. Last week I cleaned the throttle body & IAC with throttle body cleaner and the problem was fix. Believe it or not, the gas mileage went up from 13 mpg to 15.5 mpg. I'm relly glad, because winter is here! Now, my ABS lite is on, the code I'm getting are C1230, C1229, C1214, C1096 & C1095. The easy part is to replace rear ABS sensor, but the pump will be the hard part! Is there anything I can do or to repair?
Thanks again!
mgazak
19
Aug 2, 2020 09:03 AM
mikerogers56
Jun 12, 2015 06:08 PM
hackdad7725
1983 - 2012 Ranger & B-Series
Jul 31, 2014 07:13 PM
Mark_be
Dec 13, 2012 01:10 PM
holdtyte
Nov 12, 2012 10:43 PM
