that would be 49.5 hp, a little off with tubz numbers, 225-166, thats 59 hp, giving you a 27 % loss
yeah but every truck is different i'd say it ranges from 160-190 depending on wear, maintance over the years, turbo condition, injector condition.. all that good stuff
I have a link on my laptop with a site that has 17* pumps for less than $350 plus core. But if you don't have a 17* core you might have a problem. Also if you have an IH dealer that will get you parts at wholesale they are under $350 plus core but then same deal with the core unit.
how do you tell if you got the 15 or 17 degree pump?
The only sure fire way is to pull the rear cover of the HPOP to check for a bearing or a bushing. bearing is a 15* and bushing is 17*. But pretty much if your HPOP has never been changed any 94.5 to early 99 will have a 15* and late 99 to 03 will have 17*.
