Wildman
wildman chips...sounds good, especially price. how much hp can u get with it? how long have they been out there? not going to mess my truck up is it?
well, with stock injectors you can only expect about 80-90hp over stock out of any chip or tuner because that's about all the fuel AA single shots will flow. from what ive heard, tony has been around for a long time and makes a pretty flawless product. ive had mine for about 15k miles and havent had a single problem with it. so long as you have atleast a pyrometer gauge in your truck to monitor ur egt's i dont think the chip wil mess up your truck. hope this helps
-Brandon |
I've been on here a while and there is alot of very intelligent people on here that run the wildman chip! For that reason alone I believe in his product and when I get the money I will definetly have one. I don't know what you have for a truck but anytime you do significant horsepower upgrades you are risking damage unless all the preventitve steps are taken ie. tranny upgrade, gauges etc.
Dave |
Both Tony Wildman and Jody Tipton are pros at tuning the 7.3. This is what they do and they are good at it. Edge, superchips ect all make a mass produced product that works with all the 94.5-03 7.3s. Wildman or dp tiner make the engine run as smooth as stock but when you press the "go" pedal you know there is a difference. I highly recomend one of these chips as well as gauges and about $200 worth of exhaust and intake upgrades (new down pipe $150, 6637 air filter $40, gut the cat $free). I actually noticed about a 1-2 mpg increase in daily driving and I was driving a lot harder than before :)
Right now you truck is making about 180hp at the wheels. After these few upgrades you can see up to 250-260hp. It might not seem like much but it makes a big difference towing, all those hills you used to not look forward to are now kinda fun to see what you truck can do. |
180 hp to the ground? thats what they put stock. i got a kn intake, 90 hp super, and a straight pipe.
sorry if that comment seemed rude.
97's are rated 225 at the flywheel. If you want to really open it its takes injectors and bigger oil.
I have read others on different forum say that DP's 40 & 60 hp tunes feel more impressive than others 80 options with all other things unchanged.
I think that I read somewhere that the auto tranny obsorbs approx. 50 hp and the manuel not quite that much. If I recall I think that it may have been c00nhunter that came up with those figures. If it wasn't him I'm sure he will let me know chop chop.
Rog |
An actual chip that plugs into the PCM will respond better than a programmer. Plus you dont get that touchy pedal feel as with programmers.
2 stroke man please read up on k&n filters on diesel motors. Did you change out the downpipe whenever you took the muffler off? I would bet your motor is putting out 225-230 with the superchip. Better programming will get you a couple more pounds of boost as well as a smoother running engine. |
Pretty widely accepted that you lose 10-15% off the flywheel being consumed to make drivetrain work.
o ya downpipe was the very first de-slugifying move i made on my crazy mission to try to turn a 7,000 something pound lead sled into a hotrod.lol.
UPDATE: WE SEEM TO HAVE AN OUT BREAK NOWDAYS OF PMS-POWERSTROKE MODIFICATION SYNDROME |
E4's take up at least 50, it should be more like 75-80, similar to a c-6 trans power usage
i believe it's a 21-22% drivetrain loss
