I always buy my grinding burrs individually from McMaster-Carr, an industrial supply company. Cast iron builds heat up really quickly, and cheap carbides can't take heat. I would think that the Summit kit would be perfect for finish work on some of those aftermarket aluminum heads, but they probably melt like butter with cast iron.
A Dremel tool can work wonders just cleaning a head's intake and exhaust ports. Alot of heads I've looked at don't have symetrical ports and just getting rid of the excess metal can make it flow a little better. I've never worked on a I-6 head, but from this site, I've heard that alot can be done to improve flow just by reaming out the exhaust port.
There is a book called "How to Build Horsepower" that has a decent section on cylinder head porting at home. The author is David Vizard and the publisher is SA Designs.
To many people just hog out the ports as much as possible. The golden rule of porting is that is doesn't matter what you remove, it's what you leave behind. You can take out all the metal you want, but if the port shape is wrong you've wasted your time and money on a boat anchor.
Yeah, Dremel tools work great, but they get really hot. I use a1/2hp motor and flex shaft, turning a 1/4" collet. I can actually get into more places more reliably with this than with the dremel.
