Front Axle removal
Old Oct 25, 2007 | 11:49 PM
Ron Kelley's Avatar
Ron Kelley
Front Axle removal
Okay everybody. I am trying to replace all the U-joints on the front drive axle on a 1985 F-250 4X4. I believe it is a heavy duty because I am also replacing brake calipers and rotors and I have dual piston calipers and the larger size rotor 11 inch I believe it was. I also think from reading on previous posts that the hubs pretty much fill up the hole in the rim.
Here is where I am at. I am currently working on the right side. I have the right hub and the spindle off. The outer part of the axle came off allowing me to change one u-joint. The shorter part of the right axle seems to be stuck in the differential. It does move slightly but will not come out. How in the world do I get it out so that I can replace this inner u-joint. I keep reading about a inspection plate bolts and also that the diff cover needs to be removed to get at clips on the inside of the diff. I can't find any external bolts and I also do not see a diff cover that is removable.
Please help. Thanks
Old Oct 26, 2007 | 07:01 PM
Franklin2's Avatar
Franklin2
I did this on my f150. Right around where it goes into the pumpkin is a plate with some bolts. Take them off. Then pull really hard and it should come out.
When I did mine, I could not get it out, and did not want to break anything, so I took the whole pumpkin out. All you have to do is take the front driveshaft loose, and then loosen the bolts to drain the fluid, and then take the bolts out. The whole pumpkin with the little short shaft will come out toward the rear. Be careful, it's heavy. After I did this, I found out if I had pulled a little bit harder, the shaft would have come out without having to take the whole pumpkin out. But that's when I learned mine had a limited slip front, so that was neat to know.
P.S. The driver's side axle has to be pulled out to take the pumpkin completely out.
Old Oct 27, 2007 | 01:28 PM
82F100SWB's Avatar
82F100SWB
The 80 and 81 hace a bolted on retainer with a pressed on bearing, like a 9", later truck, you have to remove the differential and remove a c-clip.... It's a pain...
Old Oct 27, 2007 | 09:22 PM
Franklin2's Avatar
Franklin2
It did have a little tapered bearing on the shaft. Sorry I didn't know the later ones had c-clips. Looks like you are going to have to take the driver's side back apart and pull the axle out of the pumpkin to take the whole thing out.
Old Oct 27, 2007 | 10:20 PM
Ron Kelley's Avatar
Ron Kelley
(Right around where it goes into the pumpkin is a plate with some bolts) - I can not find bolts like your talking about here around the R/H axle shaft.
So you are saying to take the drivers side all apart and that axle will pull out of the differential? After this I can then take the diff cover off in order to remove the R/H axle shaft.
I will look into this tomorrow some more. Did not work on it today. Thanks
Old Oct 28, 2007 | 02:46 AM
82F100SWB's Avatar
82F100SWB
The DS axle will pull out.
The TTB axles don't have a diff cover per se, the axle beam is the cover.
You have to remove the differential from the axle beam.
Old Oct 28, 2007 | 12:51 PM
Ron Kelley's Avatar
Ron Kelley
((the axle beam is the cover))
OH now I see the big picture. Well just heading out to get to work on it. Wish me luck.
Old Oct 28, 2007 | 01:01 PM
Franklin2's Avatar
Franklin2
I had to do mine with 12 inches of snow on the ground. I had to shovel out around each wheel an area to work, and lay on a old piece of carpet in about 30-40 degree weather. I think that was the noreaster we got in 1996. The splines stripped on my passenger side axle where the yoke is, so I had to get a new axle and yoke. I remember replacing the u-joints too. They were the tightest I think I have ever taken apart. I took it to work, and had about 10 tons on it before it broke loose.
Old Oct 28, 2007 | 04:35 PM
troposcatter's Avatar
troposcatter
I rebuilt the front end of my 84 F150 to include all of the rubber parts and seals but I didn't have to drain the differential or replace the U joints. If the U joints are still tight and have good seals don't mess with them unless you really want to do the extra work. You cannot grease them any more, and if you screw up a seal disassembling one then you do have to buy a new one as the seals are not available. Been there and screwed that one up!
Old Oct 29, 2007 | 02:54 AM
Ron Kelley's Avatar
Ron Kelley
Just an update.
I took all the right side apart today. Removed the differential and found the stinking
C-Clip that is holding the left side in. WOW what a job. Some engineer was thinking when they did this one. Took all the parts to work tonight and cleaned everything up.
Pressed all the U-joints off and replaced them. I will start on putting stuff together tomorrow. Wish me luck.
zxwut?
34
Sep 23, 2024 10:08 PM
nossliw
Offroad & 4x4
Nov 30, 2011 08:43 PM
fordor
Oct 22, 2006 11:41 AM
Kenny
Dec 15, 2003 06:43 PM
Black Diamond Landscaping
Nov 1, 2003 06:03 AM
