1990 F150 starting problem
Old Oct 25, 2007 | 10:32 AM
mmm_hmm1's Avatar
mmm_hmm1
Hello, I have a 1990 F150 that you need to start using a pair of pliers. You turn the key to start, then there is some sort of rod in the column that you grab with a pair of pliers and push this rod towards the dash and the truck starts. Trying to figure out which part is bad and where it might be located. I have had the steering wheel off and took it apart as far as the starter key switch in the column.
Help!
Old Oct 25, 2007 | 03:17 PM
akaGWall's Avatar
akaGWall
It sounds like a broken actuator rod. It goes from the key switch down to the ignition switch that is mounted on the lower part of the steering column. You have to remove the steering wheel and turn indicator mechanism to replace it. I bought one from my local Napa store. I am sure most parts stores would have it.
Old Oct 25, 2007 | 03:23 PM
mmm_hmm1's Avatar
mmm_hmm1
Thanks, I'll check it out. I assume you have to remove the key switch to replace the actuator?
jplinville
Aug 2, 2016 06:49 PM
DG93
Aug 25, 2015 04:48 PM
Ford Blue 2000
1997 - 2003 F150
Oct 17, 2014 01:37 PM
eithernet2010
Oct 19, 2010 03:48 PM
pchristman
Electrical Systems/Wiring
Nov 27, 2007 06:17 PM
