Bed marker light removal
Old Oct 25, 2007 | 06:31 AM
Duke78's Avatar
Duke78
I have removed the bed marker lights and tail lights from my 78 shortbed, now i want to remove the wiring so i can completely pull the bed.
The marker lights run from the back and through a wall on the inside through a rubber grommet. How can i get the wire out without having to cut the grommet?
Old Oct 25, 2007 | 07:33 AM
buzzbait65's Avatar
buzzbait65
its a tight fit but the grommet pushes out of it's hole
Old Oct 25, 2007 | 11:22 AM
masterbeavis's Avatar
masterbeavis
Its also 30+ years old, and hard as a rock. You might have to use pliers and screwdrivers to convince it to come out. I am sure if you follow the wiring down the frame, you will find an area where you can completly disconnect the entire harness without having to mess with anything else. If I remember correctly, you can disconnect it right under the end of the bed.
Old Oct 25, 2007 | 12:05 PM
Duke78's Avatar
Duke78
There is a bank there to disconnect i think... I'd really like to get it out of there to blast it and repaint it correctly... I'm not sure what to do.
If i leave it in there and do my best to paint around it, it'll be a pain but if i take it out, it might really suck to jam it back in...
Any other thoughts?
Old Oct 25, 2007 | 12:17 PM
Mil1ion's Avatar
Mil1ion
Don't use a really sharp tool to push on it.
Something like a blunt punch.
first work the rubber away from the metal all the way around.
Then push the grommet out the way it is SUPPOSED to go.
The siie that goes through the metal to form the seal fits looser then the end that doesn't go thru
Old Oct 25, 2007 | 12:23 PM
Duke78's Avatar
Duke78
The grommet can only be pushed one way. It needs to come out and be pushed from the front to the back. If the right way is the opposite then i won't push it at all.
The grommet is tapered like it was installed by pushinng it from front to back, i'm going to try and just push it all the way through. Working it loose from the metal is a good idea and one i had not thought of. Thanks...
any other suggestions?
Old Oct 25, 2007 | 12:32 PM
mattimeo's Avatar
mattimeo
spray a little penetrating oil (PB Blaster is good) on it. definetly helps when pulling out old grommets.
Old Oct 26, 2007 | 06:43 AM
Duke78's Avatar
Duke78
Got them out, Mil1ion was correct. I relized that there is only one way to push them out. A little convincing from a flathead screw driver and they popped right out.
i have removed all of the wiring that was contained in the bed. All i have to do now is remove gas filler hose, the bolts for the bumper and the bed. Man those bumper bolts are on there...
Is removing the gas hoses pretty straight forward or are there any tricks to it?
BTW... I think i have the original spare tire, i removed that as well. There is no name on it, the tread is brand new on it. All it says on the tire is steelbelted radial tire. Could this be the original spare?
Old Oct 26, 2007 | 10:13 AM
masterbeavis
Without a pic, I couldnt venture a geuss. irreargdless, I would deposit it into the dumpster.
(actually, that is illegal.) Go to a used tire store, buy a used tire, leave that old one there, or put it on ebay, somebody might want an OE tire that is 30+ years old for a restoration.
Old Oct 26, 2007 | 01:52 PM
Mil1ion's Avatar
Mil1ion
Look for the size marking L78-15
I have the original tire pamphlet/warranty from the 78 truck paperwork here somewhere.
mjr46
May 4, 2016 05:32 PM
Neil64
Mar 26, 2010 06:22 AM
73f100shortbed
General Automotive Discussion
Oct 8, 2008 07:06 AM
DieselOwnerNow
Mar 31, 2008 01:19 AM
slick78
Mar 17, 2002 07:06 PM
