Converting 85 computer controlled carb to not.
Old Nov 23, 2002 | 06:27 PM
dwebb210's Avatar
dwebb210
I posted this first in the 80-86 trucks forum. Then I realized it would be better here. Sorry for the double posting.
I want to convert my '85 F-150 4.9L straight-6 from a computer controlled carburation nightmare to an older design.
Buddy of mine at Autozone looked up some parts that he thought should work from a '77 F-150.
Champion Carb, part number 6-862 $84.99
A-1 Distributor, part number 30-2669 $46.29
Wells ignition control module, part number F102 $15.99
I believe I also need the corresponding EGR valve, water temperature controlled vacuum switch, and an ignition coil.
The wires on the ignition module obviously don't match up with anything on the truck, so I'll need some assistance in determining what wire goes where.
Also, will the intake manifold that is on the truck work with the older carb and EGR valve? Or is it the same design that had been used for the past 40 years?
Are the parts listed above acceptable, or are there much better options I should know about?
THANKS!!!
Dave
Old Nov 26, 2002 | 07:24 AM
C3TZA's Avatar
C3TZA
I could be wrong, but:
What you'r suggesting will most likly work. Have you factored in the price of the cores? I use to get an awful spark knock in my '85, finally disconnected the vaccuum line to the MAP sensor (on the right fender) TFI module seems to perform as well as the older "blue, 2-plug" modules of old.
Old Nov 29, 2002 | 05:59 PM
jetta4's Avatar
jetta4
I have a 1984 that I changed to a non feedback carb. but I left the ignition system alone. I use the vacuum hoses and carb off a 1980 truck and coppied the vac. hose routing from the 1980 truck and used it. the only thing i left hook up was the map sensor . The truck run fine and passed emissions inspection.
Old Nov 29, 2002 | 07:51 PM
steve83's Avatar
steve83
Even an '83 4.9L is NON-feedback - you could collect '83 parts and do the swap, but I always recommend EFI! You'll never be sorry you did it!
http://www.webphotos.com/list_photos.asp?mi=3&smi=1&a=13217
Old Nov 30, 2002 | 03:59 PM
82F100SWB's Avatar
82F100SWB
[updated:LAST EDITED ON 30-Nov-02 AT 05:02 PM (EST)]I have an 86 F150 that's Non feedback, non catalyst and non egr... You just have to look in the right places...
The factory EFI is good to a point... It isn't very performance friendly though... I had it on my 82 until I put in what was sold to the guy I got it from as an "EFI Cam".... It wasn't, and it ran like crap... 14" of vacuum at idle doesn not keep the computer happy...
However, throw an aftermarket computer on there, and you're good to go... BTW, Steve, I am unable to view any of the pictures in your gallery.
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460 with factory 2.25" catless duals to the muffler(still running the stocker aaargh)
/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
Old Nov 30, 2002 | 09:47 PM
steve83's Avatar
steve83
Go to the webphotos home page & look for "Communities". On that page, find "Search" and put in "stevebyars@onebox.com". That should bring up a link for all my albums, including my 83 Bronco album. If you can't view it that way, then it's a problem with your computer.
Old Dec 1, 2002 | 10:16 AM
82F100SWB's Avatar
82F100SWB
All I get is this: http://www.mrhostbot.com/images/hostbotspamad.gif
Shows up for every image....
Before I switched to cable, all I ever got were broken images...
Evan
Old Dec 1, 2002 | 12:48 PM
tetraruby's Avatar
tetraruby
Works OK now Evan.
Old Dec 2, 2002 | 09:49 AM
desperado_18_2000's Avatar
desperado_18_2000
dyingtolive
300
May 19, 2026 09:21 AM
BrettMavriK
100
Jan 14, 2018 11:08 AM
Greg Rogers
Jul 26, 2016 03:46 PM
Erndale
Dec 23, 2015 07:03 AM
tworangers
1983 - 2012 Ranger & B-Series
Mar 5, 2005 10:02 PM
