Sponsored by: Real Truck
Replacing power door lock activator
Old Oct 24, 2007 | 11:16 AM
htimsdet's Avatar
htimsdet
After I remove the door panel of my 2001 F350, I am not sure how to access the activator for removal and replacement. Can anyone help? THANKS!
Old Oct 24, 2007 | 08:12 PM
rob1970's Avatar
rob1970
see this
https://www.ford-trucks.com/user_gal...=54514&width=0
Old Oct 24, 2007 | 10:27 PM
htimsdet's Avatar
htimsdet
Thanks for the detailed instructions! I'll tackle the problem this weekend.
Again, thanks.
Old Oct 25, 2007 | 07:05 AM
rob1970's Avatar
rob1970
not a problem, i need to do the same project
Old Oct 27, 2007 | 04:17 PM
htimsdet's Avatar
htimsdet
I took the easy way out and went with a aftermarket activator switch. The switch was $5.50 and easy to install. Attach the connector rod that comes with the aftermarket actuator to the rod that goes to the manual lock/unlock control. Drill two holes and mount the new actuator on the inside of the door pannel. Attach one of the wires to the red wire going to the original activator and the other to the red with black stripe wire going to the original activator. Check for polarity and you are done.
Old Oct 27, 2007 | 04:47 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
It realy easy. Iam 14 and I have done it twice on the 00 excursion,
Nick
101recon
Jun 24, 2013 07:14 PM
cjones313
Jan 5, 2005 06:35 PM
Mykro
Sep 30, 2003 10:51 PM
cbauer
Feb 21, 2003 12:22 AM
