View Poll Results: clearing battery light
75.00%
37.50%
50.00%
50.00%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Old Oct 24, 2007 | 09:26 AM
bjkidd2004's Avatar
bjkidd2004
Smile clearing battery light
cant get battery insignia or symbol to go out tried battery disconnect and fuse any suggestions
Old Oct 24, 2007 | 11:06 AM
buzzard's Avatar
buzzard
I vote for "clearing battery light." I'm gonnal watch this survey very closely.
Old Oct 24, 2007 | 11:14 AM
SMIGGS's Avatar
SMIGGS
Same here, this one will be a close one that's for sure!
Old Oct 24, 2007 | 12:12 PM
bjkidd2004's Avatar
bjkidd2004
smart a$$ let me redirect my question ,maybe not using clearing would be better. i need to turn off my battery symbol,after changing my alternator,battery is charging according to meter.
Old Oct 24, 2007 | 01:21 PM
c_hohensee's Avatar
c_hohensee
You still have a problem as there is no need to clear the battery light after changing the alternator that I am aware of. How many volts is the charging system showing. You will have to use a volt meter to get an accurate reading checking at the battery termanals with the truck running.
Old Oct 24, 2007 | 01:24 PM
SMIGGS's Avatar
SMIGGS
Calling someone a "smart a$$" and then asking for their help isn't going to get you too far. That's why I'm going to assume you are joking about your "smart a$$" comment.
If you want help, post some details on your vehicle, year, etc. Is it a new battery? Is it a new alternator. Details go along way in helping us, helping you.
And finally, it wasn't the "clearing" word we were commenting about. It's the fact that the poll has 4 of the same choices.
Old Oct 24, 2007 | 01:25 PM
bjkidd2004's Avatar
bjkidd2004
14.6v had it tested at autozone. 2002 expedition
Old Oct 24, 2007 | 01:27 PM
bjkidd2004's Avatar
bjkidd2004
new to this, and ur not the only help out there hopefully, and if u are thank u anyway
Old Oct 24, 2007 | 02:15 PM
sowder's Avatar
sowder
Chill out man, you started a poll by mistake, there just kidding with you, your right this in not the only place to get help, just the best place. now you might want to check your alt, battery, wires, and grounds
Old Oct 24, 2007 | 07:49 PM
buzzard's Avatar
buzzard
Newbie, I concur with the other guys, relax. Luckily you caught me in a good mood as normally I wouldn't reply after being called a derogatory name.
PINPOINT TEST B: THE CHARGING SYSTEM WARNING INDICATOR IS ON WITH THE ENGINE RUNNING (THE SYSTEM VOLTAGE DOES NOT INCREASE)
B1: CHECK GENERATOR B+ CIRCUIT 38 (BK/OG)
B2: CHECK GENERATOR A CIRCUIT 35 (OG/LB)
B3: CHECK I CIRCUIT 904 (LG/RD) FOR AN OPEN
B4: CHECK FOR VOLTAGE DROP IN B+ CIRCUIT 38 (BK/OG)
B5: CHECK FOR A HUNG BRUSH
PINPOINT TEST D: THE CHARGING SYSTEM WARNING INDICATOR IS ON WITH THE ENGINE RUNNING AND THE SYSTEM INCREASES VOLTAGE
D1: CHECK I CIRCUIT 904 (LG/RD) FOR SHORT TO GROUND
D2: INSPECT GENERATOR S TERMINAL C177
D3: CHECK GENERATOR FOR LOW VOLTAGE
Old Oct 24, 2007 | 07:57 PM
FTE Herman's Avatar
FTE Herman
Wow, this is the most excitement we've had here in years.
Old Oct 24, 2007 | 07:59 PM
FTE Herman's Avatar
FTE Herman
I can't edit the poll either.
Old Oct 25, 2007 | 06:45 AM
bjkidd2004's Avatar
bjkidd2004
buzzard
buzzard i have no idea what ur talking about can you possiblyuse yomens terms . check circuit 38 generator b+(bk/og)? and i will relax thanks. newbie......
Old Oct 25, 2007 | 08:59 AM
buzzard's Avatar
buzzard
FTE Herman, what did you do to our beloved Hkfus?
bjkidd2004, according to my manual, there are two scenarios when the light will come on and stay on. Both are listed above. So, you first need to determine if the voltage is steady or increasing and then we can move on to try to pinpoint.
roanokerivermud
27
Dec 5, 2017 09:04 AM
kyle j
16
Jan 5, 2012 12:25 AM
frankenstein
20
Feb 8, 2007 05:35 PM
Torque1st
1983 - 2012 Ranger & B-Series
Dec 27, 2002 09:09 AM
wolfmanagh
1997 - 2003 F150
May 8, 2002 04:38 PM
