Replacement Battery Tray
Old Aug 3, 2000 | 10:26 AM
frankenstein's Avatar
frankenstein
Old Aug 4, 2000 | 07:25 AM
samisage's Avatar
samisage
Can anyone recommend a vendor where I could get a replacement battery tray - mine has rusted away and the battery is being supported by the plastic fender insert.
I've looked in the JC Whitney catalog and all I can find are Chevy ones.
Thanks in advance.
Scott
Old Aug 4, 2000 | 08:07 AM
AlM's Avatar
AlM
try your ocal NAPA..mr gasket sells the ford trays..as well as Summit.
about $11.00
Old Feb 7, 2007 | 01:11 PM
MarineBuck's Avatar
MarineBuck
Cool Ranger battery tray problem
Ok, so I didn't know that the blot holding on the battery clamp was not meant to come totally out. I broke it off by accident. Does the bolt come all the way out from the top of the tray or from the bottom?
Old Feb 7, 2007 | 01:51 PM
SuperSnake's Avatar
SuperSnake
Thanks in advance.
Scott
Try LMC Truck,Blue Oval Parts,Dennis Carpenters,NPD National Parts Depot.
If you want a factory repro.
Old Feb 7, 2007 | 03:02 PM
Coneynew's Avatar
Coneynew
Scott:
Are you talking Full size Ford 80-86. Blue Oval sells them, but I have been collecting them from donor truks (hard to find them not rusted away). They god ones, I sand down then repaint. What I have done is take the 87-91 battery trays w/ the support bar and put them in. They fit directly over the old one and the 2 mounting holes line up perfectly and the tray is on top of the inner fender piece. You just have to make one small hole to mount the support bar. I can post pics if you want
Coneynew
Old Feb 7, 2007 | 03:20 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Coneynew
Yes please do post pics, I need a tray for my 86 but I have a 88 Bronco here I'm parting I could take everything from, that would be real helpful
Old Feb 7, 2007 | 05:47 PM
NavyMIDN08's Avatar
NavyMIDN08
please, post the pics, i'd love to see it, my tray fell apart when i took the fender off, that'd save a lot of time of fabbing up one from scratch (100 is just too much to spend from one of the supply houses)
Old Feb 7, 2007 | 05:48 PM
Coneynew's Avatar
Coneynew
I'll see if I can get some good shots - it's dark out. Give me a few minutes - I just got home from work.....
Old Feb 7, 2007 | 06:23 PM
Coneynew's Avatar
Coneynew
Here are 2 pics. Not the best, but you can just see the 2 factory bolts. The 87 tray exactly lines up w/ the old tray still in. I just reused the bolts. I had to drill a small hole to mount the support bracket (other photo). The 87 and up battery tray sits on top of the plastic inner fender vs underneath it. I remoevd the dual battery tray set up from a 87 diesel. The other one is almost a mirror of this one. It also lines up w/ the factory holes. I may add the 2nd battery to run the winch I may install. These are not the best pics since the battery is still in (sorry - but it's about 15 degrees outside right now!)
Old Feb 7, 2007 | 06:29 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
I'm going to have to try that but not now, I can relate with that 15 degrees outside its about the same here
Old Feb 7, 2007 | 06:32 PM
Coneynew's Avatar
Coneynew
I know - I am on the PA MD border. If you get the battery trays from a 87 and up, remember that some used the slots that used the 2 rods that you clamped the battery holder to, the other style has the little blocks that "squeeze" against the base of the battery as you tighten the bolts (that is that style does not have the 2 rods that come up each side of the battery)
Old Feb 7, 2007 | 06:37 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Which style do I want to use or will they both work?
Old Feb 7, 2007 | 06:40 PM
Coneynew's Avatar
Coneynew
They will both work -its a matter of personal preferemce. I light the ones that have the 2 holes for the rails, so I can use the over the battery hold down. If you see the other one, it looks like the battery is just sitting there because it is hled down at the base of the battery. Looks like you can just pick it up, but its firmly attached
Old Feb 7, 2007 | 06:43 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Cool, thank you much for the info. I'll be checking into doing this once the weather breaks.
