Removing the battery
Old Dec 3, 2002 | 02:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
Old Dec 26, 2002 | 06:27 PM
brandonlp's Avatar
brandonlp
Post Removing the battery
Hi. I have an '85 Ranger and the battery appears to be close to dead, as I can't start it and the lights are dim and wipers are slow (it's been sitting for 2 months in the cold... while I've been away at school). So today, I was gonna take the battery out and run it over to AutoZone and see if they could charge it, but I couldn't get it out. I got the negative cable off, but the positive cable seems to have a slightly stripped bolt and a whole bunch of rust-colored (though it doesn't look like rust) crud on it. Any ideas on how I can get this off? Thanks.
Brandon Pamplin
www.brandonlp.com
Old Dec 26, 2002 | 07:37 PM
mrwizard's Avatar
mrwizard
If the cable is corroded that bad you will probably want to replace it anyway. But, you can try mixing together some baking soda and water, and using that with a brush to clean the corrosion off. You can try to pry the connector open a little with a screwdriver. If that doesn't work, very carefully tap (not hit, just tap) the connector with a hammer from side to side a couple times to loosen it up. Tap it where the cable comes into the connector, not directly against the battery post. Don't try to pry the connector off with the screwdriver or hammer, you're almost gaurenteed to punch a hole in the top of the battery that way.
Like I said, if the cable is badly corroded, you should probably replace it. Disconnect it from the starter solenoid and take it with you to the store to get the right size/length.
Old Dec 26, 2002 | 08:16 PM
brandonlp's Avatar
brandonlp
Once the negative cable is disconnected, it's safe to mess with the positive one? I'm trying to avoid getting a big zap here. Thanks.
Old Dec 26, 2002 | 09:15 PM
superrangerman2002's Avatar
superrangerman2002
yes, just dont cross the terminals of the battery with your tools.
Old Dec 27, 2002 | 09:09 AM
Ken00's Avatar
Ken00
Just remove the positive cable at the solenoid and see if the battery takes a charge, if it doesn't charge don't worry about it, sounds like you need a new cable anyway.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
