solid lifter cams in 351m/400??
we luv you MAN.
later us. tell us what you KNOW, thats all we are after. paul k. our only goal is to make tim meyer and THIS forumn share and maybe even be proud of our LOW key but serious 400 midland build period. its supposed to be about going fast and building a motor that the average guy says CANNOT be done. this forumn blows that that lie every DAY paul kiernan
we luv you MAN.
As for you question on the solid lifters, danlee was correct so there wasn't anything to add to his statement. I don't think you will gain much from going to a solid cam. Your build is a low rpm build as the 2V heads and Performer intake will be all done by 5000 rpm. You are restricting the cam bearings to crutch up the reduced oil flow to the rear main bearings. That has only been an isse with high rpm motors and poorly built poorly maintain engines.
What I did with my motor is I spec'd my main bearing clearance on the large side of the factory specs and I cleaned up the lifter valley and heads to aid oil drain back. I also rodded out all of the oil passages which I know some guys just don't pay attention to when they rebuild a motor. Finally, I use a large Canton road race pan with windage tray and crank scraper plus a high volume oil pump. I'm running a hydro cam and the motor has lived for several hour worth of hard dyno time. I didn't get crazy because I don't buy into the theory that the Cleveland oil system is horrible. Does it need help in a 7500rpm motor? Yes. But keep the motor below 5500rpm and it will live longer than most people give it credit.
WHY, everything you said, is what we believe. i have heard for over 25 years. you cant make a midland run BOY. baloney, you just have to know how, right boss. you just have to understand her. period
later and thank you. you also get it, thats obvious. were havin fun now. pk
I mean, they can beat Ferrari for Pete's sake! And they don't need to cost what a Ford GT costs, either...
