VW engine for dune buggy
Old Dec 8, 2002 | 11:18 AM
82F100SWB's Avatar
82F100SWB
Old Dec 10, 2002 | 07:59 PM
motobub's Avatar
motobub
theres a dune buggy for sale fown the road with out an engine. Does anybody here know how much a used engine will cost. I ask here because you guys always seem to know.
Thanks
Lars
Old Dec 10, 2002 | 10:15 PM
GeneStoner's Avatar
GeneStoner
Stock engines are relatively cheap (Few hundred). But to really move those big tires, you will need a big (expensive) engine.
Speed costs. How fast do you want to go?
Old Dec 10, 2002 | 11:28 PM
optikal illushun's Avatar
optikal illushun
were are the smarter engine forum here :P j/k...
Old Dec 11, 2002 | 07:57 AM
larry derouin's Avatar
larry derouin
With the 4.10 gears in Herbie's rear, most any VW flat 4 will work. Depending on how well you want it to run, will force your hand.
Personally I'd use a DUAL PORT 1600 with twin carbs. Get the 1800 jugs and have the lower (center) end overhauled. Make sure ALL mating surfaces are absolutely clean and flat as the VW uses gaskets ONLY on the pushrod tubes, valve covers, oil pump, and center lower pickup filter housing. You can use about any 1 bbl carb on each side but the 2bbl dellorto will work a lot better. (Mind you I'm going back 25 years on all this so there may be more than a few changes). Get a copy or two of the VW magazines out there and look at all the options available.
Figure about $2500. to get a junkyard engine, new jugs, head job, overhaul the lower end, carbs, and other extraneous stuff.
Or you can just use a stock engine out of a 70-73 carb engine. This would be the 1600 Dual port. Next best would be 66-69 1500.
Larry
dadstruck
16
Feb 23, 2025 06:53 AM
dcowboymel
1978 - 1996 Big Bronco
Apr 22, 2013 06:43 AM
LSEYMOUR
Texas Chapter
Jun 8, 2006 09:44 PM
May 3, 2002 01:31 AM
Flash
1997 - 2003 F150
Mar 24, 2002 10:12 PM
