Grease fitting?
Old Oct 23, 2007 | 07:27 PM
ALL BOY's Avatar
ALL BOY
Grease fitting?
Does anyone know how many grease fitting I would have on my 1990 F350 Diesel, and how often they need to be greased? ? I want to lube them but dont want to leave any out.
Old Oct 23, 2007 | 08:42 PM
89frankenford's Avatar
89frankenford
well i would imagine 4 on the ball joints, 2 on the tie rods, one on the pitman arm joint, possibly 4 on the u,joints on the 2 driveshafts if you have a 4x4. thats what i can think of. when your under there just take a good look at all of your steering components.
Old Oct 23, 2007 | 10:28 PM
ALL BOY's Avatar
ALL BOY
Its a 4X4. How do I know how much grease to put into the fitting? I have found 6 fittings so far.
Old Oct 23, 2007 | 10:44 PM
89frankenford
you'll see the grease start to come out of the sides. thats when i would stop. you can also see the joint boots fill up with grease and you can stop then also.
Old Oct 23, 2007 | 10:51 PM
Skandocious's Avatar
Skandocious
You might also have some on the u-joints on the front axle shafts. But grease zerks are all dependent on WHICH parts were installed. Some u-joints and tie rod ends don't come with grease zerks...
Old Oct 23, 2007 | 10:59 PM
ALL BOY's Avatar
ALL BOY
I did not find any on eather drive shaft. What are the grease fittings on top of the front brakes?
Old Oct 23, 2007 | 11:02 PM
Skandocious
The grease zerks, if you have them, are going to be screwed into the cross-sections of the u-joints at the ends of the driveshafts. Again, not all u-joints are greaseable.
What you see on the brakes are not grease zerks, those are bleeder screws. Do not try to grease them
Old Oct 23, 2007 | 11:08 PM
89frankenford
yeah that wouldn't turn out so good if you greased all brake caliper bleeder screws
Old Oct 24, 2007 | 05:41 PM
ALL BOY's Avatar
ALL BOY
That wouldnt be good, but I know what a bleeder valve looks like and these are defenently grease fitting. They are pointing stright up from a piece on top of my front brake calipers.
Old Oct 24, 2007 | 05:49 PM
Skandocious
Trust me buddy, they do look like grease zerks, but they're bleeder screws.
Old Oct 24, 2007 | 05:50 PM
flareside_thunder's Avatar
flareside_thunder
you sure it ain't the upper Balljoint?
ztodd377
Apr 30, 2011 08:55 AM
hndacr
Feb 1, 2011 07:55 AM
SC_Dave
13
Jan 5, 2009 08:23 PM
BolderKeith
Nov 27, 2006 11:36 AM
greentools
Aug 20, 2004 09:20 AM
