Help with identifying a part.
Old Oct 17, 2007 | 08:08 PM
Fully_Loaded's Avatar
Fully_Loaded
OK My truck is DRT (Dead Right Thar). What is the capaciter thing next to the coil? Could that be a cause of problems? Help I need to get it running. I posted a wekk or so ago with no reply hopefully this one will get me started.
Old Oct 17, 2007 | 08:12 PM
TheRoadVirus's Avatar
TheRoadVirus
I'm not really sure what you're talking about.. is there any way you could post a pic? Also; is it cranking and not starting or completely dead or what?
Old Oct 17, 2007 | 08:28 PM
rbloodhound's Avatar
rbloodhound
Give us some more info on the problem. I know where the thing he is talking about is but dont know what it is. Is it not firing or what.
Old Oct 17, 2007 | 08:32 PM
Fully_Loaded
I described it in a previous post that was never responded to but I will explain again.
I can go out to crank it and the first time I will turn the key it will hit on a couple of cylinders but then nothing. I hit the key again and it might hit once then nothing after that. It is bizarre. It started out a year ago only in cold weather but it would eventuallyt start. But now nothing. I do have fuel in the rail under pressure but have not checked for spark yet. I am sure I have spark because it does hit ocassionaly but if it is strong enough I do not know.
Old Oct 17, 2007 | 08:37 PM
flareside_thunder's Avatar
flareside_thunder
could be the iggy module or that resistor that's attached to the coil.....
Old Oct 17, 2007 | 08:38 PM
ddeford78's Avatar
ddeford78
If the item you are describing has a red wire with a light green stripe, it is just the noise capacitor. Helps to eliminate engine noise coming through the radio.
Old Oct 17, 2007 | 08:42 PM
rbloodhound
The first thing that I would try is the EEC relay. It is on the driver side fender. If it hasnt ever been messed with it will be in a rectangle box. There is 2 relays in it. One is a fuel pump relay and the other is an electronic engine controll modgual. I had a problem simular to this a few years ago It would be hard to start sometimes and got worse over time. When it went out the truck was dead and wouldnt fire. I trouble shot it for a week. Change distributer and lots of tests. I was following my Haynes manual. I done all of the tests and they were good. Finaly after all of that at the bottom of the page it said if all tests good change eec relay. I changed it and the truck cranked right up.
I dont know how to tell the diffrence in the relays they both look the same. The eec relay is about $15. It is a good place to start.
Old Oct 17, 2007 | 08:45 PM
radialarm's Avatar
radialarm
The part you are trying to describe is a noise capicator. I don't think it will keep it from starting. Try removing the ignition module and take it to autozone they will test it free, and try checking every part of the ignition secondary sys. IE dist cap, rotor, wires, etc.
Old Oct 18, 2007 | 05:04 PM
Fully_Loaded
I am going to start on it this weekend. I will start with the relay then the TFI module and go from there as both are relativly cheap.
Old Oct 22, 2007 | 08:34 AM
Fully_Loaded
ok just an update, i tested the coil and the ignition module, the module checked out but the coil was low on resistance on the primary and secondary side so i replaced it and it started. I went out this morning and tried to crank it and nothing. i will try the relay next i guess. i guess it was just coincidence that it started. any other ideas would also be appreciated.
Old Oct 22, 2007 | 03:39 PM
subford's Avatar
subford
I take it you are talking about the 1991 truck.
Check for power on the + side of the coil while cranking, if no power you may have a bad Ignition Switch.
Does the fuel pumps run for one second when you first turn on the key?
If so the EEC Relay is more than likely OK.
If your fuel pumps run all the time the key is on then you may have a bad PCM Computer.
If the fuel pumps run for one second and quit and you have power on the coil with the key on then you may have a bad TFI module, PIP sensor or bad wiring in the Ignition circuit.
Old Oct 22, 2007 | 05:12 PM
rbloodhound
The fuel pump will still run with a bad EEC relay. I know from experience. I trouble shot my truck for a week.
Old Oct 22, 2007 | 05:24 PM
flareside_thunder
Thank gawd for subford...great info Bill..takes some guesswork out of things....
JR
Old Oct 22, 2007 | 05:25 PM
hugmetoe's Avatar
hugmetoe
i had a problem like that and when i worked on it there was these wires next to my distributer and they have plastic clips on them and the plugged in and everything but the heat warped the rubber on the wire and it peeled back it they keep arcing and the more i cranked the more they arc and it wouldnt start most of the time but i got started some how once went 5miles and it just shut down so i just took the damn plastic clip things off and soder them and used a lot of eletrical tape and now my truck runs even better than it ever did
Old Oct 22, 2007 | 05:43 PM
subford's Avatar
subford
The only way the Fuel pumps can run with a bad EEC Relay is if the contacts of the EEC or Fuel pump relay are welded together and then the truck will run OK however.
