I need a tech-splanation
Old Oct 21, 2007 | 06:30 PM
Medic 66's Avatar
Medic 66
Everyone...I need a tech-splanation.
What is the difference in a wireless access point versus a wireless range extender versus a wireless bridge?
I have a wrt54g wireless router and want to spread the signal around our three building campus that sits right next to each other building....
What of those three pieces of equipment do I need to run?
All is linksys manufacture that I am speaking of.
Thanks
RC
Old Oct 21, 2007 | 07:21 PM
Buckarcher's Avatar
Buckarcher
This is kind of a guess but my understanding is that the WAP is the device other devices use to connect to the internet or the local server. A Wireless Range Extender is basically a repeater, goes from the edge of the WAP's range and reboosts the signal to an additional area. I think a bridge connects 2 devices such as WAP's that wouldn't otherwise talk to each other.
I doubt you would need a bridge.
Someone might correct me though.
Old Oct 21, 2007 | 07:26 PM
herman391's Avatar
herman391
I'm pretty sure he's right but I'm no networking specialist.
Old Oct 21, 2007 | 08:03 PM
Medic 66's Avatar
Medic 66
so the WAP is built into the WRT54G router?
Old Oct 21, 2007 | 08:13 PM
Medic 66's Avatar
Medic 66
and if that is the case and I want to expand the same signal, do i just add WAP's?
Old Oct 21, 2007 | 10:51 PM
herman391's Avatar
herman391
Yes the WAP is built into the router. As I understand it to extend the range of your wireless signal you would need a Wireless Range Extended. It's a separate piece of hardware different from your router that strengthens and extends the signal be broadcast by your router.
This is off the lynksis website
Unlike adding a traditional access point to your network to expand wireless coverage, the Wireless-G Range Expander does not need to be connected to the network by a data cable. Just put it within range of your main access point or wireless router, and it "bounces" the signals out to remote wireless devices.
A wireless access point is the point where you can access a wired network and make a 'wireless bubble'. This is also right off the linksys site.
The Linksys Wireless-G Access Point lets you connect Wireless-G (802.11g) or Wireless-B (802.11b) devices to your wired network so you can add PCs to the network with no cabling hassle. Create a "wireless bubble" in that hard-to-wire home or office space, and save the time, hassle, and expense of running cables. Plus, notebook PCs can travel around your home or office and stay connected wherever they go. Since both standards are built in, you can protect your investment in existing Wireless-B infrastructure, and migrate your network devices to the new screaming fast Wireless-G standard as your needs grow.
Old Oct 24, 2007 | 07:02 PM
Medic 66's Avatar
Medic 66
OK.....thanks!!!
ford2go
Sep 14, 2017 07:29 AM
F350-6
Aug 4, 2008 05:52 AM
PowerstrokeJunkie
20
Jul 1, 2007 07:03 PM
herman391
Apr 17, 2007 04:01 PM
Medic 66
Aug 19, 2006 10:23 AM
