As my graduation present from highschool, my parents are buying me a laptop of my choice. I need a new computer, i chose a laptop over a desktop because i am going to buy AutoEnginuity software. I have a old-school Dell Dimension 8200 (yes, THAT old) and comcast high-speed internet as my ISP. Now my question for the wireless internet, how do i convert it to wireless from my wall? This may sound lame to those who know the answer, but do you just attach the cable coming out of my wall to the wireless router, that then sends a signal to the wireless card in my new laptop? Is it that simple, it sounds too easy. I'd like to place my order on my new laptop today, and i am at the place where i can select a wireless card, even buy a router. That sounds like all i would need if i am able to attach my cable internet to the router. Thanks in advance FTE.
all new notebook comps come with wi-fi already installed with B, G, or higher. a used notebook you will have to buy a card.
my question is what kind of wi-fi router do you plan on getting? if a wireless B, or G(B is backwards compatible with G and vice versa) will work fine if you plan on streaming HD video you will need something more powerfull like wireless N or higher and will have to buy a type 3 wireless N compatible card
Well, i'd like you and FTE to help tell me what to buy. I haven't bought anything as of yet, and thats why im asking, what is best. I just llooked on Dell's page and all they offer, all of them are the N wireless. Is that the best? Im not wanting to skimp on anything here.
It is that simple..
The line from Comcast goes into the internet port on the router.
Then the wireless signal just gets transmitted into the air.
Your New laptop should have wireless built in, so no need for another card.
Remember to shut down the Comcast modem for 2 minutes before connecting the router.. This will reset the modem to recognize the new router.. If you don't the internet will not work except on the pc or router you currently have connected.
Also remember to set the wireless security (WEP or WPA)..
Most people take the router out of the box and it works so they never set the security or change the router default password..
After you get your laptop you will be able to see who in your neighborhood does not have a secure network.. You will be able to connect to them..
I would just get a wireless G router.. In my opinion N is to expensive.. It does offer greater distance, but most people do not need it..
A standard 54 or 108 Mbps router is going to deliver more bandwidth than your ISP (Comcast) is going to give you. As a matter of fact 10Mbps is going to deliver more bandwidth than many high speed Internet connections. Uncompressed, raw HD video is 37MBits. But... no one serves raw uncompressed HD video. If you had several computers on a wireless network that moved huge files frequently then higher speed might be in order by N is beyond overkill for Internet access.
I recommend you get a tri-band router that supports 5 GHz. Too many people use 2.4 GHz for wireless Internet, wireless home phones, etc. Too high a likelihood for interference (even from microwave ovens). With 5 Ghz you'll have more stability with connections.
N is the latest and offers greater distance and faster speed, but costs more than the G routers.. How far are you going to be from your router? If it is under 300ft then go with G.. If you want to be out in the back 40 and still receive signal then go with N..
The brand of router is insignificant.. They all work pretty much the same..
I have used Belkin, Linksys, netgear, and No Name brands and all work fine..
I wouldn't buy from the Dell page.. You will be able to find a better deal on the net or local computer/staples store.
First off, why haven't you guys, Kris & 351911, joined your Maryland Chapter?
My Comast setup is fairly simple. Comcast modem to Linksys wireless G router. You will still need a base computer to stay connected to the Comcast modem, or at least that is what the comcast tech guy told me.
A wireless G router is probably all you need.
I have had several Linksys products over the years. All have been very reliable.
If you are buying you laptop from Dell, I would call their order line or do an online chat with a sales person to get their opinion. Buy the laptop and wireless router from the same company so you will have support installing and getting the router to work.
I wouldn't do that you will pay more. You can always find a better deal on the net.. Also the manufacturer (Linksys, belkin) will give you free support for setting up the router.
All you need is the router connected to the Comcast modem.. No need for a dedicated pc connected directly to the modem..
Cat 5 cable gives the most reliable hookup as you probably know.
Exactly... Wired is the most stable and best way to connect..
When you install your router, make sure to WPA protect it. Dont use WEP as it is becomming very easy to hack. Also, if you are going to want to file share with your desktop or share a printer wirelessly, this is a good program to use. Easy to understand and it moniters your network so that you know exactly what computer is using or trying to use your wifi.
WOW guys thanks for the inputs, keep them coming if anyone has more info to share!
....I rarely creep out of my hole in the 1999.5-03 7.3 Powerstroke Forum, however i now see that the rest of the FTE site is just as willing to help and nice as my bros in the 7.3 Forum. This site rocks.
If you get the Draft N, you'll have to upgrade your Mini-PCI card... its not worth it, G is plenty fast enough.
You can usually find a good Linksys or D-Link router from a local office supply or electronics store, for a much better price than Dell.
Dell does have one nice thing though, hop on their page and go to notebooks, and look on the top banner for Dell Outlet... they sell customer new returns, refurbished, and scratch and dent computers for 2-300$ less than new. I've bought three scratch and dent laptops, with nothing more than a scratch on the top cover not affecting anything but outside appearance.
We got a great deal awhile back on a HP laptop from Newegg.com. $489 after all the rebates. Had to up the RAM though, for a little extra. Office Depot around here has some amazing "limited quantity " deals from time to time.
After going through many hours of calls over several months time of customer service hell (it turns out they knew all along their Inspiron laptop motherboards were defective, they were just trying to deflect responsibility), I will never buy Dell again.
