Your truck lost vacuum. If it's a 4x4 and has SOTF, check those lines (They also run off vacuum). Could also be your vacuum pump or the line coming in. If you take the kick panel off under the glove box, you can see the lines back there.
do you have shift on the fly 4x4?? if so check the hubs and work your way back looking for a vac leak..when you spring a vac leak the heater defalts to defrost..
lol sorry izzy.beat me to it
Don't ask why I'm up. Well, I'll tell you anyay. Couldn't sleep well knowing a gallon or two of diesel was slowly making it's way into my drip pan...
My truck is not four wheel drive. So I should check the vaccum lines first.
Yes. And the vacuum pump in on the passenger side wheel well under the hood. When you turn your key to run waiting for the glow plug light to go out, do you hear it run for a split second? Mine kicks on then right back off right about the time the GP light goes out.
