Code Questions
Old Oct 20, 2007 | 08:36 AM
Knotwild's Avatar
Knotwild
Code Questions
I have a 1997 4x4 and the only modifications on it are a three inch down pipe and an Edge Tuner (it came on the truck). The truck has 149,000 on it. I am running the tuner at the lowest setting as I do not have a pyro gauge.
I have two check engine codes coming up. When I clear them, they reappear as soon as I crank the engine. They are:
1-Exhaust Back Pressure Sensor Circuit Malfunction
2- Turbo Boost Sensor A Circuit Low Input
Does anyone have any suggestions or experience with fixing these problems?
Thanks in advance for your help.
Old Oct 20, 2007 | 08:48 AM
c00nhunterjoe's Avatar
c00nhunterjoe
the first is a po470\478 i assume. thats nothing to worry about. it has no effect on the engine. its the exhaust backpressure valve just after the turbo. your sensor and tube are bad. the sensor is located right up ft at the high pressure pump resevoir-has a 3 wire connector the same as the icp sensor. the tube runs out of the sensor and into the right exhaust manifold.
the second sounds like the map sensor had a bad connection or somebody unplugged it at some point. make sure the senosr is grey then clear the codes and see if it comes back
Old Oct 20, 2007 | 08:49 AM
c00nhunterjoe
sorry, i just woke up, they come right back. ok what is the p0XXX number for the boost sensor circuit
Old Oct 20, 2007 | 06:36 PM
Knotwild's Avatar
Knotwild
Code Numbers
I checked the codes using the diagnostics on the Edge Tuner and it does not return numbers, only the description. Dennis at ITP Diesel said the same thing you did. I think I will order the parts from Ford on Monday and replace them.
Where is the MAP sensor located? I have never had to deal with this before. Also, will those problems effect the engine performance?
Thanks very much for your help.
Old Oct 20, 2007 | 06:53 PM
tjbeggs's Avatar
tjbeggs
MAP sensor is located in the passenger side on top of the HVAC box. it has a 1/4 rubber line running to it. try running the truck once with the connector unplugged. if the truck runs better you need a new sensor. if it doesn't run better you may have other issues like low boost.
Old Oct 21, 2007 | 11:51 AM
Knotwild's Avatar
Knotwild
Quick Question
C00nhunter:
Does the MAP sensor attach to a Y shaped bracket over the heater box? I checked it based on where you told me it was and found that there is no sensor there. I did find an unattached 1/4 inch hose and unattached wiring harness. I miss my old 6.9 sometimes or I guess I should just admit I don't know much at all!
Thanks for sharing all you know with the ones of us that need help.
Old Oct 21, 2007 | 01:10 PM
c00nhunterjoe
lol thats the spot where is the sensor?!
Old Oct 21, 2007 | 01:48 PM
Knotwild's Avatar
Knotwild
Sensor, What Sensor?
I just bought the truck about a month ago from a guy who said he was the third owner and it checked out with CarFax. All he had done to the truck was add the Edge tuner. It looks like someone took the sensor off for some reason as one of the mounting screws is still in place. He may not have even known it was missing. I plan to get one ordered from Ford on Monday.
Thanks
Old Oct 21, 2007 | 02:16 PM
c00nhunterjoe
you should see a difference in the trucks performance after install
Old Oct 21, 2007 | 03:08 PM
tjbeggs's Avatar
tjbeggs
WOW that is a first! boost leak and no sensor. I acidently ran my truck with the hose unhook and I thought I traded it in on an IDI but atleast the connector was also undone so your truck ran on preset readings.
Old Oct 21, 2007 | 03:49 PM
Cuda_jim's Avatar
Cuda_jim
Man are you going to be happy when you get that sensor back in there. Lots more HP
That's unreal, maybe someone stole it?
Old Oct 21, 2007 | 03:56 PM
c00nhunterjoe
i beleive the correct term is "borrowed"
Old Oct 22, 2007 | 06:33 AM
Cuda_jim's Avatar
Cuda_jim
Still gets the same amount of lead in their azz whether it's borrowed or stolen
BTW: Here's the PN
MAP Sensor
(Ford) F4TZ-9F479-A (94-98; digital)
Old Oct 22, 2007 | 02:52 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
http://good-times.webshots.com/photo/2810049160099659029swKcgK
Schematic and pic (this one from TJ)
Old Oct 22, 2007 | 03:02 PM
tjbeggs's Avatar
tjbeggs
Hey look nobody stole my sensor! well that pic is old better go check! there is a thief about! I still can't beleive that truck did even have the MAP there! that kills me!
