Getting ABS error code 4.
Old Oct 19, 2007 | 07:29 PM
shelbyville's Avatar
shelbyville
Well I finally tracked down my flaky brake light problems to and ABS issue, specifically error 4. This appears to be the only error that will also trigger the red brake light which explains why they were both coming on at the same time.
<TABLE borderColor=blue cellPadding=3 width=400 border=1><TBODY><TR><TD vAlign=top>4 *</TD><TD vAlign=top>Open/grounded Valve Reset Circuit</TD></TR></TBODY></TABLE>
* Red brake warning lamp illuminated
I found this article that explains how to trouble shoot an error code 4 on your ABS system. My only question is, where is this control module it talks about in step 1.
1) Turn ignition off. Disconnect neg. battery terminal. Disconnect control module connector. Gently pull on terminal No.6 (light blue/red wire) of control module and control harness connector. If the connector terminal is fully engaged and corresponding terminal of control module is okay, leave control module disconnected and go to the next step. If terminal is loose or has pulled out of connector, repair or replace terminal or connector as necessary and go to step 12. If control terminal is loose, bent, deformed, corroded or missing, replace control module and go to step 12.
2) Disconnect and inspect 4-pin valve assembly connector. Valve assembly is located on left frame rail, towards the rear of the engine compartment. Gently pull back on terminal 2 (light blue/red wire) and terminal 3 (black/white wire) of valve assembly connector and valve assembly harness connector. If terminals are fully engaged in connector, leave valve assembly disconnected and go to the next step. If terminals are loose or have pulled out of connector, repair or replace terminals or connector as necessary and go to step 12. If valve assembly terminals are loose, bent, corroded or missing, replace valve assembly and go to step 12.
3) Using an ohmmeter, measure the resistance of Light Blue/Red wire between control module harness and connector terminal 6 and valve assembly harness connector terminal 2. If resistance is less than 10 Ohms, go to next step If resistance is greater than 10 ohms, repair open in Light Blue/Red wire and go to step 12.
4) Using an Ohmmeter, measure resistance between terminal 3 (Black/White wire) of valve assembly harness connector and ground. If the resistance is less than 3 Ohms go to next step. If the resistance is graeter than 3 Ohms repair the wire and go to step 12.
5) Using an Ohmmeter, measure the resistance between terminal 6 (Light Blue/Red wire) of control module harness connector and ground. If resistance is more than 12 ohms, go to next step. If resistance is less than 12 ohms, repair short to ground in the wire and go to step 12.
6) Using an ohmmeter, measure resistance between terminal 2 (reset) of the valve connector and valve body (ground.) Ifresistance is more than 10 k/ohms go to step 8. If resistance is less than 10 k/ohms, replace valve assembly and go to step 12.
7) DEALS WITH AEROSTAR AND RANGER (OMITTED)
8) Measure resistance between terminal 2 and terminal 3 of valve assembly connector. If resistance is more than 10 k/ohms go to step 10. If resistance is less than 10k/ohms, replace valve assembly and go to step 12.
9) DEALS WITH AEROSTAR AND RANGER (OMITTED)
10) Perform testing under INTERMITTENT DIAGNOSIS. If intermittent open is found, repair as necessary and go to step 12.
**If you need that step email me**
11) Ensure all preceding diagnistic steps have been completed and involving wiring integrity has been verified. If not go to last diagnostic step completed and continue from there. If all diagnostic steps have been completed, replace control modeule and go to next step. If control module has already been replaced with no resolution of problem, replace valve assembly and go to next step.
12) Ensure ignition if off. Reconnect negative battery cable. Ensure all connectors are secure. retrieve trouble codes. If Code 16 is present go to code 16 under TEST DRIVE. If code 4 is present, go to next step. If any other trouble code is present, go to appropriate test for corresponding trouble code.
**If you need those tests email me**
13) Ensure all preceding diagnostic steps have been completed, and involved wiring integrity has been verified. If not, go to last diagnostic step completed and continue from there. If all diagnostic steps have been completed, go to nect step.
14) If previous diagnostic steps have been completed, problem is most likely wiring related. Go to INTERMITTENT DIAGNOSIS and preform tests on involved circuits. If problem is not resolved, go to step 11. If problem is resolved, repair is complete. Go to CODE 16 under TEST DRIVE. For additional testing, see CODE 4 under TEST DRIVE.
Old Oct 21, 2007 | 11:55 PM
Rockledge's Avatar
Rockledge
You're looking for the ABS control module?
What year is your Ranger, and which engine?
Old Oct 22, 2007 | 08:46 AM
shelbyville
Sorry. That would help. Its a 90 Ranger with the 2.3 L engine.
Old Oct 23, 2007 | 07:53 PM
shelbyville
Bump....Come on someone must know this. Don't make me go out and buy a Clilton manual
Old Oct 23, 2007 | 08:02 PM
Rockledge's Avatar
Rockledge
If it helps, this is out of a '92 Ford Manual:
The Ranger RABS module is located in the dash under the instrument panel. Mounted to a brace, center of panel area.
Removal
1. Disconnect the wiring harness from the RABS module by depressing the plastic tab on the connector and pulling the connector off.
2. Remove the screws that retain the module to the instrument panel bracket. Remove the module.
Old Feb 28, 2008 | 04:12 PM
Wolfpackdawg's Avatar
Wolfpackdawg
did you ever resolve your problem? I have the same exact problem with my 90' Ranger with the 2.3L....Thanks!
Old Feb 29, 2008 | 11:46 AM
shelbyville
Yes I did. Cost me 800.00. It was the proportioning valve that was bad. It eventually started leaking. Its located inside the frame rail on the drivers side. Almost directly under the drivers seat. The valve was 250.00 but the bleeders were all rusted solid so I had to go for new lines, calipers in the front, and cylinders in the rear. Works great now. It should for 800.00.
Old Feb 29, 2008 | 12:10 PM
Wolfpackdawg
I appreciate the info...I'll check that out on mine along with the other things I have read that it could be.
John-Oswego
Sep 30, 2019 01:04 PM
cheezit
Jun 24, 2010 07:16 PM
1972-34ton
Jul 27, 2009 10:47 PM
mattklionsky
1997 - 2003 F150
Aug 2, 2001 11:00 PM
MacWizard
Feb 14, 2000 04:21 PM
