Temperature Sender Resistance
Old Feb 14, 2000 | 08:15 AM
MacWizard's Avatar
MacWizard
Does anyone know what the resistance of the temperature sender should be in an '89 F250 351M?
My temp needle dips slightly when powered on. I measured the sender resistance across the two connector pins, and it's 17.8 k-ohm with the engine slightly warm. The two pin connector is supplying 4.6 vdc to the sender (measured across the pins), and the temp gauge connector in the instrument panel supplies 12 vdc across the lower left terminal to the top terminal (triangular terminal orientation). I also measured the impedence of the gauge, 109 ohm lower left pin to top pin, 50 ohm top pin to lower right pin, and 58 ohm across both lower pins.
Thanks,
Greg Calder
Old Feb 14, 2000 | 08:16 AM
MacWizard's Avatar
MacWizard
I meant to mention that the gauge never moves from the dipped position as the engine warms up.
Thanks,
Greg
Old Feb 14, 2000 | 11:24 AM
PAUL_2's Avatar
PAUL_2
Gary,
The chart Im looking shows at 50 deg F OAT, the ACT should have 3.51v and the resistance should be 58.75 Ohms on the X scale . Those things may set fault codes if its been very cold . What led you to inspect it in the first place ?
Paul
Old Feb 14, 2000 | 02:06 PM
MacWizard's Avatar
MacWizard
Paul,
What is an ACT sensor? Is it the temperature sender?
I checked the temperature sender because the gauge always read "C". I figured it was just the sender, but just wanted to be sure, since I have the volt meter.
What is the X-scale. When using a diagnostic test tool?
Greg
Old Feb 14, 2000 | 03:28 PM
PAUL_2's Avatar
PAUL_2
Gary ,
Im sorry ...for some reason I thought you were try to diagnose The Air Temp Sensor . I was talking to someone at the time I was typing the previous post and got my wires crossed . Sorry for the confusion .
Paul
Old Feb 14, 2000 | 04:21 PM
Ed Bamba's Avatar
Ed Bamba
Roader
24
Jul 21, 2024 08:27 AM
77f250weos
Jul 16, 2013 11:18 PM
kg6jmz
Jun 12, 2010 06:47 PM
924x2150
18
Aug 29, 2005 09:49 PM
wdj
Apr 22, 2004 09:40 PM
