full throttle stumble
Old Oct 18, 2007 | 08:25 PM
MAKO314's Avatar
MAKO314
what will cause a high RPM miss or stumble. this only happens on acceleration.
my mods are BTS dual HPOP,injectors,H2E turbo,DP Tuner,6637 filter, external reg fuel system,fuel bowl delete,BTS trans. these are the major mods,could any of these cause the high end full throttle stumble?
Old Oct 18, 2007 | 08:54 PM
Izzy351's Avatar
Izzy351
You've eliminated the HP oil problem with the dual-HPOP, you have an excellent tuner, a big-dog turbo, and big injectors (I guess -- which ones do you have?). The only thing I could think of that might cause it is a bit of fuel starvation. Do you have a completely upgraded system from the tank to the heads or is some of it stock? Is it tossing any codes? Any smoke?
Joe
Old Oct 18, 2007 | 09:03 PM
ron's power stroke's Avatar
ron's power stroke
i am probly wrong but want to take a guess...LL injector in #8 hole????
Old Oct 18, 2007 | 09:06 PM
Izzy351's Avatar
Izzy351
Nah Ron... He's got after-market injectors.
Old Oct 18, 2007 | 09:08 PM
ron's power stroke
lol damn..i need to read a little closer...
Old Oct 18, 2007 | 09:10 PM
Izzy351's Avatar
Izzy351
lol.... You're cool -- I'm still making my list of to-dos for this weekend. Some truck, some my other hobby. Neither of which the wife will be happy with.
Old Oct 18, 2007 | 09:13 PM
ron's power stroke
i tell my G/F thats what makes a good relationship...making up can be fun
Old Oct 19, 2007 | 07:49 AM
MAKO314's Avatar
MAKO314
I changed the oil and filter and the problem appears to be gone. I was running royal purple oil apparently the PSD doesn't like it.
Old Oct 19, 2007 | 08:07 AM
ron's power stroke
glad you found it...
Old Oct 19, 2007 | 08:10 AM
Izzy351's Avatar
Izzy351
That's interesting -- RP is supposed to be really good stuff. How many miles were on it and what did you put in to replace it??
Joe
Old Oct 19, 2007 | 08:11 AM
Donny_D's Avatar
Donny_D
on the oil note i was using ats diesel oil full synthetic... truck didnt like that either it had an off kilter ilde sounded like the timeing was off or missin on a cyclinder didtnt make me to happy for the price
Old Oct 19, 2007 | 08:13 AM
Kwikkordead's Avatar
Kwikkordead
I was going to suggest that you were bouncing off of the rev limiter.
I am also curious on what kind of oil was used this time around.
Old Oct 19, 2007 | 08:31 AM
MAKO314's Avatar
MAKO314
I put schaffers full sythetic back in , I've ran that since the truck was new and had no problems. I just up and decided to try the RP this time and it did fine under normal driving but at full throttle at the strip last weekend it fluttered and stumbled.I haven't tried the schaffers in the new 08 yet has anyone heard of any problems with it in the new 6.4 ?
Old Oct 19, 2007 | 08:36 AM
Izzy351's Avatar
Izzy351
I haven't heard anything, but I'm sure Schaeffers will do fine it. But then again, I thought the same thing about RP...
BTW, how'd you do at the track, even with the stumble at WOT?
Old Oct 19, 2007 | 08:46 AM
ron's power stroke
maybe the mix of the 2 oils didnt agree.making air bubbles in the oil.much like adding additives to the oil..check this out
http://www.bobistheoilguy.com/images/lucas/lucas.htm
