full throttle stumble
Old Oct 19, 2007 | 11:26 AM
CanadianSmokie's Avatar
CanadianSmokie
I have heard that Rotella-T is one of the better oils for anti foaming. Sounds like that might be the problem you are experiencing with your injectors...
Old Oct 19, 2007 | 03:12 PM
FN74's Avatar
FN74
Another item to consider, especially with dual pumps. This is an issue I am having. And that is too much of a good thing. Too much high pressure oil that is blowing open the poppets on the injectors and basically disabling the injectors. As injectors wear, their ability to handle HPO above 3000psi is reduced. Oil viscosity plays a huge role in this as well. My engine has a very small window where it is warm but not hot that allows the injecotrs to work at WOT without this occuring. Royal Purple is a very good oil and may very well actually increase the tendency for the injectors to pop open on the HPO side.
If you got ALL NEW injectors, then this may not be your issue, but most aftermarket injectors are rebuilt and likely can not handle HPO in excess of 3,000 psi. Just some food for thought if you notice your issue continuing....
Old Oct 19, 2007 | 04:02 PM
jhand124's Avatar
jhand124
I have been running Mobile 1 Delvac full synthetic. It made a huge difference during the winter on sub zero starts. Anyone else been using it?
broncoderek
Nov 30, 2013 07:38 PM
Lovin7.3
80
May 8, 2008 10:41 AM
yellow401
16
Aug 15, 2006 08:22 AM
jpttaylor
Jan 17, 2006 11:40 PM
craigthowell
Modular V8 (4.6L, 5.4L)
Aug 17, 2003 01:05 AM
