Rear Main Seal Help
Old Oct 18, 2007 | 11:57 AM
newfordguy77's Avatar
newfordguy77
Rear Main Seal Help
Well my 77 F-100 seems to be leaking oil from the rear main seal. Ive seen it run off of the bellhousing before. It only starts once the truck is started and is running for a few mins. But do i have to pull the motor when replacing the seal?? its a 3spd manual on it,2wd
Old Oct 18, 2007 | 07:14 PM
doehnter's Avatar
doehnter
You don't have to pull the engine. But you do have to pull the transmission,clutch and flywheel.
Old Oct 19, 2007 | 03:34 PM
Gary B's Avatar
Gary B
Make sure mains are good or the seal will not last.
Old Mar 11, 2009 | 10:29 AM
Tees77f150's Avatar
Tees77f150
I know this is an older thread, but I have the same issue with my 77 F150 300 I6 2 WD. It has a C4 which I know I have to pull, but do I need to drop the rear main to put this rear seal in? And If I do, does anyone know the torque of the main bolts.
Also, there is 80,163 miles, what are your thoughts on replacing the oil pump while I am in there?
Old Mar 11, 2009 | 10:48 AM
Gary B's Avatar
Gary B
rear main seal
Hi, The seal is a one piece design, similar to the front cover seal.
Drill a small hole in the seal, insert a screw and use it to pull the seal out. Very difficult to install without proper driver but if you are very careful it can be done with a hammer and punch. be sure to drive it in evenly. Lube the lip of the seal.
You can not remove the oil pump without removing the pan so i would not be concerned about that unless you noticed a problem with oil pressure. Be careful with the seal installiation, have done the job many times. Gary
shore
1978 - 1996 Big Bronco
Nov 14, 2013 12:01 AM
dyoungen
Mar 22, 2013 02:58 PM
Jimmyrig
Jan 18, 2013 10:01 AM
matt71
Jun 23, 2008 03:31 PM
Talled20
Sep 10, 2003 02:19 PM
