Rear Main Seal
Old Jun 22, 2008 | 03:29 PM
matt71's Avatar
matt71
Rear Main Seal
My rear main seal in the oil pan is starting to leak pretty good. Can this be changed with the motor in the truck? If so how hard of a job is this?
Old Jun 22, 2008 | 04:20 PM
Cuda_jim's Avatar
Cuda_jim
Are you sure the rear main seal is bad?
It's not in the oil pan but on the back of the block. The trans needs to be removed to service it.
If the oil pan gasket is leaking you will need to lift the engine a foot or so to get the oil pan off.
Old Jun 22, 2008 | 04:22 PM
Cuda_jim's Avatar
Cuda_jim
Be sure to look on the top of the engine for liquids, oil or fuel.
Look way down in the valley, most leaks start up there and then run down the rear of the engine looking like a rear main seal/oil pan gasket.
Old Jun 22, 2008 | 05:02 PM
heathrunkles's Avatar
heathrunkles
Yep x2 what cuda said. The Orings on mypedestal went oand started niagra falls both forward into the valley and back on top of the tranny. I couldn't beleive the amount of oil that came out so quickly. Everything is coated back to the rear bumper, but good news is it is a great rust deterent.
Old Jun 23, 2008 | 01:44 PM
matt71's Avatar
matt71
I took the dust cover off the bottom of the tranny and i can see the oil leaking out the seal on the oil pan right where the oil pan curves around the crank. I also have oil leaking from the front behind the thermostat.
Old Jun 23, 2008 | 03:31 PM
Cuda_jim's Avatar
Cuda_jim
Sorry Bad news, That's the oil pan gasket. You need to lift the engine about a foot or more to get the pan off for the repair. Big job, just as much work as pulling the engine out of the truck.
limptera13
Apr 1, 2010 01:43 PM
DT 466Man
Apr 29, 2005 10:41 PM
WXboy
1983 - 2012 Ranger & B-Series
Nov 15, 2002 12:00 PM
honney
1978 - 1996 Big Bronco
Jan 13, 2002 05:06 PM
