Carb expert needed
Old Oct 18, 2007 | 09:33 AM
straightsixer's Avatar
straightsixer
Carb expert needed
Hey all, I am fighting an extremely rough idling gremlin. From partial throttle to wide open my 6cyl runs good but once up to temp (choke fully open) I have to feather the throttle to keep it running. So far I have replaced cap/rotor, plugs, fuel filter and pump and rebuilt the carb.
Am I barking up the wrong tree in thinking it's an air/fuel issue at idle or more like an airleak somewhere? Is the air/mixture screw the only way to richen up the idle mode or is there something else I can tweek?
Old Oct 18, 2007 | 10:15 AM
rswhitmore's Avatar
rswhitmore
Have you checked to see what your manifold vacuum is? Symptoms could indicate a intake vacuum leak.
Old Oct 18, 2007 | 10:39 AM
straightsixer
No I haven't tried that yet. Don't have vacuum gauge would I need one?
Old Oct 18, 2007 | 10:33 PM
Harte3's Avatar
Harte3
$15 Vacuum guage available at any parts house is one of the best investments you can make for trouble shooting and tuning.
Old Oct 19, 2007 | 12:37 AM
Ford_Six's Avatar
Ford_Six
Make sure the carb hasn't worked loose. They liked to do that, especially the Ford Model 1 carbs on the earlier 300-6. The Carter wasn't as bad as that or the Autolite/Motorcraft carbs, but still did it.
What year is your truck, and does it have power brakes, a/c, EGR, etc?
Old Oct 19, 2007 | 08:44 AM
straightsixer
Yep, I've had the carb work loose alittle in the past but it's plenty tight now and yes it has power brakes. It just seems like it's a lean at idle problem cause when after the choke opens fully the idle goes to crap. Is there a way the richen up the idle circuit on these carbs?
Old Oct 19, 2007 | 09:19 AM
javi2001's Avatar
javi2001
Yea sounds like lean hot idle condition.
The main control for fuel delivered is the fuel level at bowl. Then the mixture screw.
Check/adjust float level, clean all internal passages at carb body. I'm assuming there are no vacuum leaks, remember, carburetor delivered proper fuel amount ONLY for air passing through its barrel
Old Oct 19, 2007 | 10:00 AM
jas88's Avatar
jas88
Sometimes the body will get loose from the base, you gotta check that too. Sounds like a vac leak of some kind to me.
Old Oct 19, 2007 | 03:32 PM
Gary B's Avatar
Gary B
With throttle off idle slowly close choke plate, any improvement in idle indicates vacuum leak or carb problem.
Check for vacuum leak by spraying cheap carb cleaner spray around all gaskets and vacuum lines and look for improvment in idle. pinch off any vacum lines in question and look for same results. Good Luck
