Electrical Question
Old Oct 17, 2007 | 09:08 PM
Tater97's Avatar
Tater97
Electrical Question
Ok Fuse #8 blows No power locks, no courtesy bell, no odometer, no speedo, no overhead light. Does anybody have a simple schematic or a common point of reference for the 97 obs with this problem? Help....TAter
Old Oct 17, 2007 | 09:13 PM
tjbeggs's Avatar
tjbeggs
Yep I had the same problem on my 95. I think it was the #8 fuse but all those things didn't work. I needed a new keyless entry module. If you unplug it you won't have power locks or dome lights but the fuse won't blow anymore. The module has 3 long flat connectors and is under the dash to the right of the steering column.
Old Oct 17, 2007 | 09:14 PM
c00nhunterjoe's Avatar
c00nhunterjoe
to the junkyard batman
Old Oct 17, 2007 | 09:31 PM
Tater97's Avatar
Tater97
yep #8 is the one...too dark to see right now but will do in the am ...any further remedies...Tatr
Old Oct 17, 2007 | 10:21 PM
rtxcoon's Avatar
rtxcoon
rings-n-things....
you wont care anymore ...well after a few weeks anyway...
kinda tendersome..
your fuse is gone...
Old Oct 18, 2007 | 06:06 PM
tjbeggs's Avatar
tjbeggs
Did you make any progress today Tater?
Old Oct 22, 2007 | 04:03 PM
Tater97's Avatar
Tater97
Yes TJ that was it. So when I get the new module I'l get locks and light back? Thank you much...Tate
Old Oct 22, 2007 | 04:09 PM
tjbeggs's Avatar
tjbeggs
thats the way it went with mine. The module i got form the salvage yard lasted a few weeks then did the same thing. they gave me another one and it was good from then on. just a note they are the same modules that many other fords use so just check around. I got mine for $50.
Old Oct 26, 2007 | 09:47 PM
fasmust's Avatar
fasmust
When the fused popped, did you get erratic shifting from the tranny also?
Old Oct 26, 2007 | 09:51 PM
tjbeggs's Avatar
tjbeggs
yes the tranny will shift very harsh. but that could be caused by other stuff too if you don't have any blown fuses
Old Oct 26, 2007 | 10:00 PM
fasmust's Avatar
fasmust
I did have the same fuse blown, and I didn't realize till I found a link in another thread to a picture of the fuse layout that it is definitely number 8. The fuse blows, and I have been carrying some with me and changing it on the fly. I'm going to try disconnecting that module tomorrow to see what happens. Thanks a ton for your help!
Old Oct 27, 2007 | 10:42 AM
fasmust's Avatar
fasmust
Well, I don't have a keyless entry module, so I guess I have to go through every module on the circuit . It looks like there are a bunch of them.
