390 ID #'s
Old Nov 12, 2000 | 12:11 AM
possum's Avatar
possum
390 ID #'s
I have 2 sets of 390 heads and one set of 352, one sets #'s are (4A18 &4A24), another set is (1A27 &1A21), and the other is (5E7 & 5D3 this set has FoMoCo on them.) Thanks for any help to ID the heads.
Thanks Possum
Old Nov 12, 2000 | 09:34 AM
390fe's Avatar
390fe
390 ID #'s
Possum, look between the middle two spark plugs on the heads for the casting number. The numbers you posted are date codes and are not much help in identifying your heads.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old Nov 12, 2000 | 11:58 AM
possum's Avatar
possum
390 ID #'s
The other #'s are (D2TEAA with a big 203 by it), (D1TE with FA by it), and (C4AE with 6090G by it.) Thanks for the help.
Thanks Possum..
Old Nov 12, 2000 | 01:10 PM
possum's Avatar
possum
390 ID #'s
The other #'s are (D2TEAA with a big 203 by it), one is (D1TE with FA), and the other is (C4AE with 6090G by it). Thanks for any help.
Thanks Possum..
Old Nov 13, 2000 | 03:52 PM
scoutsmotorsports's Avatar
scoutsmotorsports
390 ID #'s
> The
>a big 203 by it),
>with 6090G by it).
D2TEAA-'72-'76 360,390,428 w/o air-68.1-71.1 cc chamber
D1TE-'71 heads for the same thing
C4AE-'64-'65 352,390-71.2-74.2 cc chambers.
Old Nov 15, 2000 | 04:11 PM
fordification's Avatar
fordification
390 ID #'s
What year do you think is the best non-hipo heads for a 390FE? As in the smallest chambers, largest valves, and possibly best port dimension. My heads are C8AE-H I think. The CC size is 68 to 72cc, with 2.02I and 1.65E size valves. This is just a standard cylinder head, but I figure have respectable numbers.
~'71 F-100 Sport Custom Reg.Cab
-390FE w/Edelbrock Performer RPM intake, 780cfm Holley, ported & polished cylinder heads,
Crane Cam (0.548"I,0.580"E), 10.5:1 CR, Black Jack headers, true double roller timing chain, and high volume oil pump
-C6 transmision w/B&M 2600rpm stall
-9" Ford Rearend w/4.10 Richmond Gears & 31 spline axles
-215/65/r15 Yokohama's for the front & 28"x13.5"x15" Mickey Thompson ET Street slicks for the back
Best 1/4 mile time @ 3375ft altitude 14.69secs @ 92mph
~'98 F-150 XLT Reg. Cab Flareside 4x4, Black, 5.4L, 3.55LS, tow package, 285/75/r16 Mud Terrain BFG's,K&N, GTS headlight covers, Alpine changer w/FM mod, Clifford alarm system w/keyless entry & starter disable // Future considerations: Bed mat, tonneau cover, 4" suspension lift or 3" body lift.
~2000 Suzuki RM125 Dirt Bike
-no need for any modifications! (yet)
Old Nov 21, 2000 | 02:53 PM
stryder's Avatar
stryder
390 ID #'s
Old Nov 24, 2000 | 10:34 PM
390fe's Avatar
390fe
390 ID #'s
The C6AE-R heads are identical as far as ports to the 428CJ, but you'll have to install the oversize 428CJ valves.
Jason Kendrick
stu37d
22
Nov 4, 2010 03:33 PM
possum
15
May 31, 2001 10:06 AM
possum
Ford vs The Competition
52
May 23, 2001 03:27 AM
possum
13
Feb 14, 2001 04:56 PM
possum
Nov 24, 2000 10:25 PM
