390 to 427??
Yep..All that stuff is FE stuff and will work with just about an FE motor. The blocks are the same configuration. It's just the rotating assemblies that change. Well, that and the bore size.
There are some unique 427 pieces. But, if you plan to use your intake and heads, that should not be an issue.
You're only issue, will be finding or paying for a 427. The 428 is a little easier to come by. Both, are more expensive than the 360/390 blocks.
Another option is to stroke your 390 block. Using a 428 crank or aftermarket crank..
Rusty_Old_F250
Jun 29, 2011 08:32 PM
tylstruck
Feb 2, 2008 04:36 PM
mk
Feb 14, 2002 09:24 PM
FE427TP
Jul 7, 2001 03:01 PM
