stock turbo?
Old Oct 15, 2007 | 03:21 AM
Donny_D's Avatar
Donny_D
stock turbo?
kind of turbo is on early 99 PSD f350 was just wonderin cause i was lookin at mine today and just was curious and 99.5 and later if anyone know would appreciate thanks
Old Oct 15, 2007 | 04:48 AM
ron's power stroke's Avatar
ron's power stroke
the turbo on the right of both pix is the early 99 turbo..one on the left is for 99.5 to 03 trucks..
spider on the right is the ealy 99..as you can see the early 99 is a lot smaller and flows less air..more pix in my exploded view in my sig
Old Oct 15, 2007 | 09:00 AM
MTDewX's Avatar
MTDewX
Can't beat that explanation.
Nice one Ron
Old Oct 15, 2007 | 12:23 PM
lukecline's Avatar
lukecline
I would rather have the early99 turbo. It flows about hte same and has 0 surge problems
Old Oct 15, 2007 | 01:28 PM
Badluck's Avatar
Badluck
yea im very happy with my early 99..... but more power is on order so its gotta go
Old Oct 15, 2007 | 01:36 PM
ron's power stroke
I swapped mine to a stock 99.5 and added the wicked wheel..I run 100 to 150 degree cooler on the EGT's now and i have no surge what so ever.even with red line un hooked.even though an update was needed and I would get more power by doing the HPOP I'm very glad I swapped over..now i can hold it to floor a lot longer...
Old Oct 16, 2007 | 03:37 AM
Donny_D's Avatar
Donny_D
ok so the next question is are the 99.5 and later that much better as far as higher boost it obviously has more air flow and are they easy to interchange? will it fit right in place of the smaller one or will there be a problem with it fitting nicely in the same spot?
Old Oct 16, 2007 | 04:25 AM
ron's power stroke
you dont build any more boost..you still only get 25 to 27lb. it moves the power rang up a little..meaning i lost a little low end power but gaind a little more on top..i also run 100 to 150 cooler on EGT's..if you want more SOP power..swap out the HPOP to a 2000 and up...as far as swapping turbo's you need the up pipes, babies butt, turbo, pedistal, spider pipe and intake plenums..pix in my view of a 7.3 shows you the parts...i got all my parts from a donor truck to do my swap..but Bob has a kit here to do this as well
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=276
Old Oct 16, 2007 | 07:55 AM
beansdiesel's Avatar
beansdiesel
If you have a early 99 and looking for an upgrade our Dominator 66 fits the bill very well. It will flow more air for better peformance and at the same time bring down egts nicely. Its a heck of alot easier then changing all the stuff to go to a late model setup.
Shawn MacAnanny
Dec 15, 2016 09:53 PM
travisp_95
Oct 6, 2012 05:11 PM
Awitte58
33
Apr 4, 2012 03:42 PM
colorado99_f250
Aug 12, 2010 09:45 PM
rfrunk
20
Jul 10, 2007 03:43 PM
