tech question
Old Oct 14, 2007 | 09:59 AM
banjopikr's Avatar
banjopikr
tech question
can anyone tell me the correct timing for a '78 ford f100 with a 302? thanks in advance...
Old Oct 14, 2007 | 10:40 AM
429f150's Avatar
429f150
well I looked at my dads 78 f150 302 and the sticker says 2deg btdc
Old Oct 14, 2007 | 10:52 AM
fairhand's Avatar
fairhand
can anyone tell me how to find an fuel vaccume leak?
Old Oct 14, 2007 | 11:06 AM
Mil1ion's Avatar
Mil1ion
Welcome to you both new users.
Please read post #1 on this thread.
https://www.ford-trucks.com/forums/1...ease-read.html
Information on 1977/78/79 Trucks engine specifications can be found on this page of mine.
Calibration codes are pertinent to some degree
http://www.clubfte.com/users/mil1ion...e-upSpecs.html
Fuel Vacuum leak ?
For vacuum hose leaks..use an unlit propane torch pointed at vacuum connections
Old Oct 14, 2007 | 11:13 AM
Mil1ion's Avatar
Mil1ion
Not 302's are set the same.
they vary from 6* - 12* BTDC .....It depends on numerous things.
axle ratio,transmission type,state of operation,altitude
The calibration code on the white sticker on the valve cover is the key to the engine specs.
Old Oct 14, 2007 | 11:26 AM
fairhand's Avatar
fairhand
Thanks will give it a try.
Old Oct 14, 2007 | 11:28 AM
fairhand's Avatar
fairhand
Also what will the propane reaction do?
Old Oct 14, 2007 | 11:29 AM
Mil1ion's Avatar
Mil1ion
The engine will speed up.
Old Oct 14, 2007 | 12:27 PM
fairhand's Avatar
fairhand
thank you.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
