front and rear axle gear ratio 73 f250
I have a 73 F250 and my axle code is b47. On a decoder I used it says that it is dana 60 front and rear with 4.55 in front and 4.10 limited slip in the rear. I saw another guy posted that he got the same results but had a different code. Just curious I dont think it is possible but would like to find out if maybe the vin decoder I used was wrong and I really at this point dont wont to pull the diff cover off or count wheel revolutions. My other 73 axle code is 24j the decoder says invalided code. thanks
B47 ? Looks correct to me.
1973/79 Ford Truck Parts Catalog sez in General Info Section, page 62:
B4 is rear axle code.
B4 = Dana 60 / 4.10-1 / Limited Slip / 5300 lb Rear Axle Capacity
7 is front axle code (1973/75)
7 = Dana 44-6CP / 4.55-1 / 3500 lb. Front Axle Capacity / without Power Steering
There's also two other 7 codes...one for 1976, another for 1977.
Originally Posted by Mil1ion
They must have dropped the Front axle code in later years ?
I wish hipoparts would scan a newer printing of the 1973/79 parts catalog...it would be very beneficial to y'all with later info, and who don't have microfiche readers (and hence the actual Ford slides, which are still available from Ford [@$110.00 a set]).
grizzlyadams73
08-14-2003 09:42 PM
grizzlyadams73
08-13-2003 05:02 PM
