Rear bumper mounting brackets
Old Oct 13, 2007 | 07:55 AM
Customcab's Avatar
Customcab
Ran into alittle difficulty mounting a smooth rear bumper onto my buddies 77 F100. We use the brackets from a 68 F100, got the same mounting points on the bumper as a 77 rear bumper but the mounting holes on the frame (77 model) only alines up with one hole. I would think the bracket would be interchangeable from both models. The only measurement difference from the two trucks was the distance of the frame rails, but the bumper calls for a 40" on the 77 model and 36 1/2" on the 68. The brackets holes onto the frame is where the problem is.
Any suggestion, and does a late 70's model differ from a late 60's style brackets???
Mitch
Old Oct 13, 2007 | 09:32 AM
75F350's Avatar
75F350
Almost 10 years difference and a body style change is bound to leave some things a little bit different.
Is popping a couple new holes not an option? Seems like that would only take a mater of minutes.
I would think you have the choice of drilling the frame, or the bracket. If one bolt holelines up already, you are most of the way there already.
Old Oct 14, 2007 | 07:15 PM
Customcab's Avatar
Customcab
75F350; That's exactly what where going too have to do; I will have to drill thru both outer bracket arm arms and frame. Also its a smooth chrome bumper so theres no towing etc.
I notice several different styles of frame hole combo's this weekend from 68 thru 78 frames. It seems like they place them (Frame mount holes) where ever they wanted.
Mitch
Old Oct 15, 2007 | 03:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964/72 F Series Styleside rear bumper brackets: C4TZ-17787/88-A .. R/L inner; C4TZ-17795/96-A .. R/L outer.
1973/79 F100/350 Styleside rear (non-step) bumper brackets: D3TZ-17787/88-C .. R/L inner; D3TZ-17795/96-C .. R/L outer.
Old Jun 15, 2008 | 07:06 PM
306_rapes's Avatar
306_rapes
Is there a place I can buy the brackets for a 79 styleside F100 with the smooth bumper?
I need them badly!!!!!!
Old Jun 15, 2008 | 08:26 PM
Dr. Dirt's Avatar
Dr. Dirt
check the sponsors; ftepartsguy, NPD, blue oval truck parts, bronco graveyard, auto krafters, etc.
moparmusclecars
Mar 20, 2012 10:52 AM
Psyclopse
Jan 22, 2012 12:11 AM
BC_Caprice
Jul 5, 2010 07:41 PM
scottw383
Jul 20, 2006 02:04 PM
averagef250
Nov 4, 2004 07:05 PM
