Old Jan 27, 2006 | 09:28 AM
FalconStng's Avatar
FalconStng
The is no external way to see the difference between a 360 and a 390. Checking the stroke will determine which crank you have and that will generally let you know. You still need to measure the bore to be positive. I used 360 pistons in my 390. My 390 is a truck and had the low compression pistons. The 360 pistons only have the valve relief cutout plus they go higher in the cylinder too. With the 360 pistons and the 390 rods and crank the pistons are about .012" below the deck at TDC. That's not too bad.
Old Jan 27, 2006 | 10:14 AM
gizmo3194's Avatar
gizmo3194
Thanks for the quick reply.
I wasn't ready for teardown but I will be very soon. The motor still is running good.
Again, Thanks for the reply
Mark
Old Jan 27, 2006 | 02:23 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Mark to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 28, 2009 | 12:39 AM
madfordman's Avatar
madfordman
im putting 360 flat tops in my 68 390 for more compression as for external parts i have a 390 with a 360 water pump and oil pan and the starter is a 360 automatic on a 390 standerd any thing fits from one to another
74f100sc
15
Feb 23, 2016 11:26 PM
Hercules
Mar 30, 2012 08:19 AM
Paco
Mar 14, 2005 06:15 PM
SuperFord
Sep 17, 2004 10:17 AM
specialz
Apr 12, 2003 11:23 PM
