Backfiring
Old Oct 12, 2007 | 07:26 PM
77F250Custom4spd's Avatar
77F250Custom4spd
Originally Posted by danlee
How old is the cap and rotor?
Check the cap for cracks and look for signs of tracking.
As far as i know they are original, maybe theyve been replaced once not sure though
Old Oct 12, 2007 | 07:34 PM
77F250Custom4spd
Originally Posted by RJR99SS
A backfire is pretty much always caused by the wrong timing, either ignition or cam.
If all you did was replace the plugs and wires, and it ran ok before, then you know something is wrong with the wire routing. A bad wire or plug will make it run rough, but i dont think it'll cause a back fire.
Check the wires again... firing order should be 13726548 counter clockwise. I'd remove the number 1 spark plug, and turn the engine over until number one piston is tdc on it's compression stroke, then take the cap off and make sure the rotor is pointed at number one, then check the firing order from there.
How do I tell when its on the TDC on its compression stroke?
Old Oct 12, 2007 | 07:44 PM
danlee's Avatar
danlee
Replace the cap and rotor!
Old Oct 13, 2007 | 09:56 AM
RJR99SS's Avatar
RJR99SS
The easiest way is to take the plug out, rotate the engine over until the balancer is on 0, hold your thumb over the spark plug hole while you're turning it. If you feel pressure coming out you're on the compression stroke, if you dont you're on the exhaust stroke and you need to spin it around 1 more time. to make sure it's at tdc, you can just put a little wood dowl or something down in the spark hole, once you get to 0 it SHOULD be at tdc...that is unless your balancer has slipped, in that case you'd need the stick of wood and watch it until the point where it wont go any higher.
But once you're sure you're at tdc on the compression stroke, just pull the cap off and the rotor should be at, or close to the number one plug. If it is, then like i said check your firing order from there.
Old Oct 13, 2007 | 09:48 PM
77F250Custom4spd
[QUOTE=RJR99SS] rotate the engine over until the balancer is on 0,QUOTE]
Sorry dont know what or where the balancer is
Old Oct 14, 2007 | 01:24 PM
RJR99SS's Avatar
RJR99SS
[QUOTE=77F250Custom4spd]
Well....the balancer is the circular thing down at the front bottom of the engine below the water pump. It's got a lot of marks on it, with a little timing pointer bolted to the block pointing to it.
Old Oct 14, 2007 | 04:14 PM
77F250Custom4spd
[QUOTE=RJR99SS]
Oh, I know what you mean.
Well I think I found the problem. Popped the cap off and the metal piece that spins around on the end of the rotor (dont know what its called) was busted clean off.
Hmann
Mar 6, 2010 08:22 AM
MikeFlorida
Feb 18, 2007 05:23 AM
bobonut
Jan 11, 2005 12:33 AM
Icicle
Mar 1, 2004 05:56 AM
badexpresso
Feb 13, 2004 04:43 AM
