Backfiring
Old Oct 11, 2007 | 09:06 PM
77F250Custom4spd's Avatar
77F250Custom4spd
Backfiring
I just replaced the plugs and wires on my truck and now when I start it it runs for 15 seconds or so then starts to backfire real bad then dies even if I try to keep it running with the gas pedal. Then if I try to start it again it takes awhile to get it started again.
I have checked the wires many times and they are all in the correct place. None of them are crossed.
oh its a 1977 400
Ill bet Mil1ion has an answer for me
Old Oct 11, 2007 | 10:25 PM
mark a.'s Avatar
mark a.
Champion plugs ? Autolite ?
Old Oct 12, 2007 | 06:58 AM
danlee's Avatar
danlee
How did you replace the wires?
Did you replace them one at a time, or did you remove all of them and replace the whole set?
Old Oct 12, 2007 | 07:29 AM
73XAFalcon's Avatar
73XAFalcon
Just what I was thinking. You have 2 wires crossed. Trace your plug wires back and see which 2 you swapped.
Old Oct 12, 2007 | 07:36 AM
danlee's Avatar
danlee
Or he started the firing order one terminal off of #1. The #1 mark on the cap may not truly be #1.
Did you also replace the cap and rotor?
Old Oct 12, 2007 | 09:40 AM
fmc400's Avatar
fmc400
MSEE
I have been told that on a 400, you can't let the #5 and #6 plug wires run parallel. That means you can't clip them down next to each other on the valve cover. Instead of clipping them as 5, 6, 7, 8 you should do something like 5, 7, 6, 8. This is said to be because cylinders 5 and 6 fire right after each other per the 400 firing order which causes inductive coupling problems if the wires run parallel too much. This will cause crossfiring issues.
I can't readily say that I believe it, but I've seen it in enough places, including my 400 build book, that I think it's at least worth looking at.
Old Oct 12, 2007 | 12:18 PM
77F250Custom4spd
Champion Plugs
Old Oct 12, 2007 | 12:19 PM
77F250Custom4spd
One at a time
Old Oct 12, 2007 | 12:20 PM
77F250Custom4spd
Nope didnt replace the the cap or rotor
Old Oct 12, 2007 | 12:25 PM
77F250Custom4spd
I rearranged those wires and still does the same thing
Old Oct 12, 2007 | 01:32 PM
mark a.'s Avatar
mark a.
Try putting the old plugs basck in & see. I've had problems with Autolite & Champion.
Old Oct 12, 2007 | 02:49 PM
77F250Custom4spd
There already in the garbage dump
Old Oct 12, 2007 | 03:15 PM
danlee's Avatar
danlee
How old is the cap and rotor?
Check the cap for cracks and look for signs of tracking.
danlee's Avatar
danlee
Sorry Duplicate.
Old Oct 12, 2007 | 03:19 PM
RJR99SS's Avatar
RJR99SS
A backfire is pretty much always caused by the wrong timing, either ignition or cam.
If all you did was replace the plugs and wires, and it ran ok before, then you know something is wrong with the wire routing. A bad wire or plug will make it run rough, but i dont think it'll cause a back fire.
Check the wires again... firing order should be 13726548 counter clockwise. I'd remove the number 1 spark plug, and turn the engine over until number one piston is tdc on it's compression stroke, then take the cap off and make sure the rotor is pointed at number one, then check the firing order from there.
