squeaking when turning left
Old Oct 11, 2007 | 03:26 PM
matt11902's Avatar
matt11902
I have a 2000 F250 7.3 liter superduty and I have noticed in the last few days that when I'm driving on the highway I hear a squealing/squeaking when I vear to the left. I can barely turn the steering wheel and I hear the sound. When I go right, there's nothing. Anyone ever heard of this? Thanks guys
Old Oct 11, 2007 | 04:12 PM
empiretc's Avatar
empiretc
if it a 4x4 its probably a needle bearing
Old Oct 11, 2007 | 07:07 PM
F350-6's Avatar
F350-6
The answer is simple. Only turn right.
Does the noise only happen when driving or can you duplicate it at idle? Is it 4wd or 2wd? Is it a constant noise like a whine, or an intermittent squeak like something needing to be greased?
Give us a little more info and I'm sure we can help.
Welcome to FTE.
Old Oct 11, 2007 | 09:57 PM
matt11902's Avatar
matt11902
It is a 4wd and it doesn't do it in idle, just when I'm driving. And it happens with the slightest turn of the wheel. It's also a pretty constant noise that sounds like a squeal almost, kind of like something could be rubbing, but as soon as the wheel straightens it's gone immediately.
Old Oct 12, 2007 | 06:18 AM
F350-6's Avatar
F350-6
Then I'm with empiretc. Time to check the bearings.
Old Oct 12, 2007 | 08:12 AM
empiretc's Avatar
empiretc
the only problem there is they are "non-serviceable". You would need to replace the entire hub or try this:
http://guzzle.rbmicro.com/nblube.html
Only reason I know, is cuz my buddy's 4x4 was doing the same thing. It was a bad squeal though, like strangling a cat every time he turned left. Driver side bearing was out.
Old Oct 12, 2007 | 08:22 AM
7.3L DID TD's Avatar
7.3L DID TD
Unhappy
I'm troubled empiretc, just how do you know what a cat being strangled sounds like.
Old Oct 22, 2007 | 09:21 PM
matt11902's Avatar
matt11902
So i've noticed that there is no noise at all when making a left turn, or when in idle and turning the wheel. There is only noise when traveling at highway speeds and when the wheel is slightly turned to the left like when following the curve of the highway. The noise immediately disappears when it's back straight or when it's turned farther left.
Just wanted to give a little more information in case you guys had any more ideas. I really appreciate all your feedback, so thanks.
Old May 19, 2024 | 09:30 PM
Bradly.stevens's Avatar
Bradly.stevens
8th Gear
Old post
I know this is a long shot but I am having the same EXACT problem. Did you ever find an answer?
HighRiskJob
1997 - 2003 F150
Sep 16, 2014 09:22 AM
AkF250HD
Aug 7, 2013 06:31 PM
Glockem45
Apr 4, 2012 05:24 PM
WickedSharp
Jan 13, 2011 09:10 PM
forddd
1997 - 2003 F150
Aug 10, 2006 10:22 PM
