Sponsored by: Auxito
squeak when only turning wheel left
Old Jul 12, 2006 | 09:27 PM
forddd's Avatar
forddd
I have a 97 f150 4x4 and whenever I turn the wheel to the left at low speeds or at a stand still, it squeaks (it sounds like the ball joints need to be greased). However, I recently replaced and greased both ball joints and both tie rod ends and the squeak continues to exist. Any possible solutions to this problem would be helpful. Thanks
Old Jul 13, 2006 | 05:18 PM
LxMan1's Avatar
LxMan1
Welcome to the forum.
Pitman arm possibly? You say both ball joints, do you mean both lowers or the upper and lower on the one side?
Old Aug 10, 2006 | 09:15 PM
forddd's Avatar
forddd
upper and lower on both sides...i talked to my friend who is a mechanic and he said that it is probably the pitman arm too. Thanks for the feedback and ill let you know how it goes when i put the new pitman arm in
Old Aug 10, 2006 | 09:33 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
Yep,pitman arm.Mine was squeaking too.I used my grease needle to grease it;no more squeaks!
Old Aug 10, 2006 | 10:22 PM
BrianA's Avatar
BrianA
Ditto. Used to have a 97 Expy that did the same thing. Made a tiny hole in the rubber cover and squirted it full of grease.
Never squeaked again.
shaneinga
Apr 27, 2012 02:10 PM
kass
1983 - 2012 Ranger & B-Series
Nov 1, 2011 12:10 PM
Aggie.2012
2004 - 2008 F150
Jun 12, 2011 03:32 PM
Ryno22980
Jun 30, 2010 09:19 PM
spdmpo
13
May 28, 2010 10:17 PM
