I am looking at buying a '74 250 Crew cab with a 390 in it. Two 390 owners have told me they overheat easily. I'd really appreciate some input on this.
Actually, a stock 390 is less likely to overheat than most others. I've always thought of these engines as 'cold blooded' in stock form.
If it has been bored, has higher compression or some other mods, it might become an issue.
The FE has at least two pully sets, one for A/C one for non-A/C. The stock A/C pullies cause the water pump to spin faster and helps with cooling. Edelbrock makes an alum water pump for the FE for about $150 and these trucks offerd a 'dessert cooling' package that included a 4 row rad that sits down into the frame and up 5/8" from hitting the hood.
The point is that you have many effective options, I went with the largest rad, alum water pump, opened the head water passages to the intake, 10qt oil pan, 18" fan, A/C pullies, stock fan shroud, 160deg high flow TStat. I'm running a high compression 428 and I don't think I could get it to overheat if I wanted it to.
karljay—thank you for the input. Your comments are encouraging. I have not owned a Ford truck since 1973, when I bought a new Econoline with a 302, and now I feel its time to get back to where I once belonged.
You should be in good shape if you have your radiator checked out and flushed (repaired if necessary) by a radiator specialist. I did the above with my 390 GT, which does run fairly high compression and sees a lot of fooling around, and I don't have any problems with overheating, even in 85+ degree heat. And I'm in the half without radiator shrouds. I seem to be out of neckties now, too. That's what I get for wearing clip-ons!
