For those with brake problems!!!
Old Oct 10, 2007 | 08:54 AM
RubberDuck's Avatar
RubberDuck
Okay guys, for those of you that have a falling pedal, grabby brakes etc......
"ZERO LOSS BRAKE BOOSTER"
I tried replacing the RABS module, no help.
I replaced the stock master with an F450 master (bigger bore) no help.
Thank the good lord for Tim Beggs!!! My brother in law told me about it, but Tim provided the motivation in the form of confindence that it would work, and a part #. THANK YOU TIM!!!!!!
For those of you that want this part, you have to go to Ford and order it by this specific # F5TZ-2005-CA It's called a zero loss booster. I paid $141 for it.
I don't know how in the hell it fixed the problem, or why. But it did. It makes no sense how a booster could cause this to happen (falling pedal, grabby brakes) But it did. This FIXED my problem.
So there it is, my conclusion to the brake booster question. I hope this helps all you that have posted threads on it. See ya on the boards.
Old Oct 10, 2007 | 09:20 AM
tjbeggs's Avatar
tjbeggs
Great to hear that it worked! I really don't see how it works either but I guess it does. Every single OBS truck I have driven (alot!) have done the failing brake pedal deal. On my 95 I replaced everything except the brake booster and brake lines to fix the problem and finally decided to live with it since they all did it. Now we have a fix that works! Thanks for the update Cody!
Old Aug 21, 2010 | 09:41 AM
Brown Falcon's Avatar
Brown Falcon
Good info, this is the problem with mine right now.
Old Aug 23, 2010 | 08:17 AM
Talyn's Avatar
Talyn
I wonder if this would fix my brake issues.
It, on occasions, feels like I have no brakes at all.
Then again, I don't have the vacuum can any longer either. I should go get one of those f-150 ones and stick it in.
Old Aug 23, 2010 | 03:16 PM
cowmilker08's Avatar
cowmilker08
I have the problem too.
I replaced the calipers, "cylinder pistons", pads, shoes, and replaced the master cylinder.
I bled the brakes like you wouldn't believe.
I'll try this fix some day. Thanks for the heads-up.
Old Aug 23, 2010 | 05:05 PM
strokin'_tatsch's Avatar
strokin'_tatsch
can this be made a sticky???
Old Aug 23, 2010 | 07:43 PM
Brown Falcon
I agree... sticky!
Old Jan 18, 2012 | 03:44 PM
dougbrown's Avatar
dougbrown
Just called ford for one and they want 247.99 with tax.
Old Jan 18, 2012 | 04:13 PM
tjc transport's Avatar
tjc transport
i ain't rite
Originally Posted by Brown Falcon
I agree... sticky!
it all depends. what is in it for me??
Old Jan 18, 2012 | 04:30 PM
dougbrown's Avatar
dougbrown
Your own tray of bread pudding at the swap meet. How that?
Old Jan 18, 2012 | 04:53 PM
tjc transport
i ain't rite
stuck!!!!
and i will hold you to that promise!!
ya know, you never posted the recipe for it last year either!
Old Jan 18, 2012 | 05:30 PM
dougbrown's Avatar
dougbrown
I will work on that for you.
Old Jan 19, 2012 | 08:15 PM
RubberDuck's Avatar
RubberDuck
Sweeeeeeeet!!! I finally got a sticky!!!!!!!!
Old Jan 26, 2012 | 05:15 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
So, on my '97 drag truck, when I was building boost for a launch, the pedal would eventually go all the way to the floor.
Would this booster have helped that?
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jan 26, 2012 | 05:42 AM
tjbeggs's Avatar
tjbeggs
Yes it would have!
