Swapping to LED bulbs
Old Oct 9, 2007 | 10:27 PM
mr. dave's Avatar
mr. dave
Has anyone tried this. Am in the process of doing this on my '07 Peterbilt with the lights on both sides of the air cleaners and under the cab and sleeper. I have LED cab/clearance lights but am going to replace the 1157 bulbs in the turn signals and possibly the tail lights.
Any advice or experience would be apprieciated.
thanks, mr dave
Old Oct 10, 2007 | 08:15 PM
FordF350Baby's Avatar
FordF350Baby
Ya I have replaced all the bulbs on my truck (roof lights, turn signals, parking lams, and taillights) with LED bulbs. They look awesome and u cant see them thru my clear lenses. On the taillights you may need to run equalizers to draw more power to the bulb because they use way less energy and u may also need equalizers for your turn signals if u decided to do that...
Old Oct 21, 2007 | 05:40 AM
ron's power stroke's Avatar
ron's power stroke
every bulb on my truck has been up graded to LED's..even did my gauges and stock cluster with blue LED's..you do need 2 resisters..one for each turn signal..I put mine behind the tail lights to keep them from getting wet..the resister's do get very warm as well..so make sure they don't touch another wire...buy the color bulb for the same color lens..(red lens red bulb) clear lens add what color you want...I have left my parking lights on for 10 hours twice..I thought the truck would never start...turned the key and it fired right up..the LED's use very little current..I even added green eyes to my truck with green LED's..
Old Oct 21, 2007 | 02:52 PM
Imdok's Avatar
Imdok
Resistors Size
Where else can one buy the LEDs to replace your rear lights (Turn/Brake and Running)? I saw some in a NPD parts catalog. They came in three different sizes (amount of bulbs) for the same bulb number (1157, etc.). The bigger (more bulbs) the better?
Will they work on my 1982 F250?
What size resister with what size bulb do you use?
Thanks
Old Oct 21, 2007 | 02:55 PM
Imdok's Avatar
Imdok
Brighter?
I almost forgot.........are they hugely brighter than your standard bulb? Sort of like those halogen bulbs they came up with that burned out fairly often?
Thanks fo any info
Old Oct 21, 2007 | 03:50 PM
ron's power stroke
Thanks fo any info
there a lot brighter and last alot longer then bulbs....
http://www.superbrightleds.com/carbulb-notes.htm
Old Oct 21, 2007 | 08:27 PM
CobraXP's Avatar
CobraXP
I've bought most of mine through this company:
http://www.superlumination.com/
Seems about the same as the link above. Myself and a lot of others have had good luck with this company.
Old Oct 26, 2007 | 04:04 AM
blue beast's Avatar
blue beast
You can make the led light for any base bulb you want, Just break the glass add a
resistor and the leds and solder them in, for some time you will save alot of money
and you can vary the brightness and color of the leds for a custom look that nobody
else has think a blue led in the center of your 1157 like the blue dot lenses back in the day!! Look up Luxeon leds they are the brightest leds out yet and noone that I know
has them in the premade led lights, put them on your aircleaner and they may be too
bright and your truck will definately stand out in the sea of now seemingly dim led
chicken light trucks!! http://www.theledlight.com/LuxeonLEDs.html They are more
expensive but if you see one you will know why, Some bicycle headlights are using
the luxeons and you have probably seen them kind of a bluish white really bright head
light it was probably a luxeon they don't last long on battery power but we don't
have to worry about that!!
Old Oct 26, 2007 | 02:26 PM
Imdok's Avatar
Imdok
Solder King I'm Not
Too many part choices at the above link, plus I'm no great fabricator of electronics.
Which manufactuer has THE best and brightest product out there now?
I like the idea of those folding wing lights as you can get a bigger light into the bulb hole in the rear lens housing.
Ideas?
Old Oct 26, 2007 | 09:02 PM
mr. dave's Avatar
mr. dave
LED's
I got my bulbs from an online vendor called v-leds, www.frickinbright.com. The 194 bulbs were about $2 apiece and the 1157's were $20 a pair. Supposedly got a discount because I ordered 50 plus bulbs, and that was just to replace the current bulbs.
Old Oct 26, 2007 | 09:56 PM
MIKE1646's Avatar
MIKE1646
How about the dash lights? How do they look?
Old Oct 29, 2007 | 09:01 PM
mr. dave's Avatar
mr. dave
LED's
Have not done the dash lights, I'm in the process of doing all the outside marker lights, cab & air cleaner lights. Also doing the the turn signal and brake/tail lights.
Old Nov 1, 2007 | 04:46 PM
ron's power stroke
with LED's they glow more then they light up...not so hard on the eyes..
Old Nov 21, 2007 | 04:17 PM
flareside_thunder's Avatar
flareside_thunder
I put LEDS in the tailights of my 95 F-150.......how do I add the resistor and where?And how big of a resistor?Thanks.
JR
GORDEN1234
2015 - 2020 F150
Mar 6, 2017 08:13 PM
06greenstroker
Jan 9, 2017 02:11 PM
Mr. PC
2004 - 2008 F150
May 27, 2015 01:24 PM
bneafus
Jan 24, 2012 12:33 PM
Supercab
Jun 20, 2010 08:05 AM
