6.0 Programmer advice needed
Old Oct 10, 2007 | 08:51 PM
  #31
npccpartsman's Avatar
npccpartsman
Originally Posted by dfuser
That is beacuse the Dyno computer spitted that info on the sheet. I'll have to get that doctored to show the actual numbers.
Write him a dyno tune and you won't have to "doctor" it.
Old Oct 10, 2007 | 08:53 PM
  #32
dfuser's Avatar
dfuser
[QUOTE=blackhat620]You may want to add this little fact to your website, since it says this module is safe with all stock trucks and Cruise Control (don't think i need cc at the sled pull) just add gauges and go!
"Steroid Power Module with Dual Adjustable *****
Adds up to 85HP-150ft lbs of torque! (Stock Truck-No Chip)
Increases oil pressure to injectors.
Quick install! Now works with Cruise Control.
Fully stackable with other chips!
We HIGHLY reccomend the use of gauges with this modification as this can cause high EGT levels when turned up.
For all 6.0L Powerstrokes 2003.25 - Up"
www.dfuser.com/mfg/powerstroke/60/performance.php[/QUOTE]
This information is still true. In the case of the truck mentioned above it was specifically tweaked for SLED pulling. You can still safely add the Steroid Module to any programmer. The gains will not any where on the top with a proper written program. But you also need to realize there are a lot of generic programs out there.
I'll add a note about custom programs and the compatibility.
Old Oct 10, 2007 | 08:59 PM
  #33
npccpartsman
Somehow safe and high EGT's just don't seem to fit in the same category
Old Oct 10, 2007 | 09:00 PM
  #34
dfuser's Avatar
dfuser
btw: Thx for keeping me on track!
Old Oct 10, 2007 | 09:22 PM
  #35
blackhat620's Avatar
blackhat620
The "Safely Add" statement is were i disagree, anytime you give the average truck owner the ability to alter the MAP sensor readings and ICP with the turn of a **** and absolutely no way to monitor PFP (peak firing pressure) & MEP (mean effective pressure), you are creating a recipe for disaster to both the 6.0 & Torqueshift.
In addition stacking any inline module with a generic program is also a recipe for disaster with the 6.0 & Torqueshift. The writers of the genetic programs had no idea that someone would stack on top of their program. Again this can lead to excessive PFP & MEP leading to rapid failure of the 6.0 not to mention the added stress on the Torqueshift that will go unaddressed.
Old Oct 10, 2007 | 10:12 PM
  #36
bogginf350's Avatar
bogginf350
I have been pulling sleds for quite awhile and I sure wouldnt want to have to try to turn ***** while I was pulling.
Chriso83
Jun 20, 2013 11:41 AM
FORD_F-350.
Feb 27, 2012 10:51 AM
AndeyHall
Feb 12, 2010 08:18 AM
stroker_8
Nov 18, 2009 07:54 PM
