6.0 Programmer advice needed
Old Oct 10, 2007 | 08:13 PM
blackhat620's Avatar
blackhat620
Originally Posted by dfuser
Honestly where did you come up with this? Are you a programmer? Please enlighten me....
If the programmer knows what they are doing and can write proper tuning programs for the SCT, then an inline module is Not needed. An inline module stacked with an SCT is a bandaid to poor custom tuning plain and simple.
Old Oct 10, 2007 | 08:16 PM
npccpartsman's Avatar
npccpartsman
Do I need to go get a real programmer to enlighten YOU???
Old Oct 10, 2007 | 08:21 PM
dfuser's Avatar
dfuser
Again what are you basing your data on? Have you written a tune in the SCT Software?
The module controls the MAP and ICP.
The code was written specifically for SLED pulling and having the Steroid adjustability on the fly to meet variying condition on the track.
This is not the proper place to argue the point. Many hours over several months where put in to insure that specific truck is successfull on the track.
Old Oct 10, 2007 | 08:25 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
There is not 475 horsepower of fuel in the stock injectors, period.
Any number produced at this level by the stock injectors has had the dyno manipulated, period.
You can ask Eric @ Innovative. You can ask Tadd @ Elite. You can ask DJ @ DJ Diesel Performance.
475 RWHP is a manipulation of figures and is not accurate. It simply is not possible without aftermarket injectors.
The steroid module does nothing but manipulate ICP signal voltages. A properly trained calibrator does not need any such device to force the IPR valve to 99% duty cycle. It is also not neccessary to manipulate the MAP sensor in order to obtain the correct amount of boost.
With proper tuning, the Steroid module is useless in a stacking application...and regardless, 475 RWHP is physically not obtainable on a "stock" truck in the trim you describe.
npccpartsman
Things that can be done with the SCT that don't need a plugin module.
Old Oct 10, 2007 | 08:27 PM
dfuser's Avatar
dfuser
There was no manipulation of data, just facts. Its up to you to believe what you see. I'll leave at that.
Old Oct 10, 2007 | 08:34 PM
SpartanDieselTech
Former Vendor
For anyone not trained looking at the dyno graph; please see the green line (of which the numbers are based off of).
Do you see the LOOP, where the engine speed actually gains then drops? This is called a "shift spike"; an error in the graph caused by the upshift of the transmission. Anyone who is skepictal; please take a look at the graph for yourself.
The real numbers appear to be in th 440hp range- which is right inline with most "hotter" tunes you will get from any of the reputable dealers.
This is an absurd and inaccurate way to rate horsepower and torque production.
blackhat620
One more time, if the person writing the custom tune for the SCT knows the 6.0 & Torqueshift, an inline module to trick the MAP sensor readings and ICP is not needed. Maximum Hp & Torque can be achieved with a well written program for the SCT without the use of stacked modules. Inline trickery is not needed with the SCT and proper programming.
Furthermore an inline module that tricks the MAP sensor readings and ICP, at the users will with the turn of a ****, is a quick way to serious engine problems since the user has know way to monitor PFP (peak firing pressure) & MEP (mean effective pressure).
This is the exact place to argue this point since the OP that brought up this specific topic claims to need this inline module stacked with an SCT to produce max Hp & Torque. The inline module is not needed if proper programming is done with the SCT.
Old Oct 10, 2007 | 08:36 PM
npccpartsman
The facts of that dyno graph are that shift spikes are posted as peak horsepower and torque and it's BOGUS. If you read the real graph curve he doesn't get more than 440hp and 760 tq. That's facts.
Old Oct 10, 2007 | 08:37 PM
npccpartsman
Originally Posted by npccpartsman
He's claiming 472hp and 1006 torque but he's using shift spikes to base his numbers on which is BOGUS. Maximum hp is less than 440 and only 560 tq on his best run. Good HP but terrible torque. If I wanted to claim shift spikes I could claim WAY higher numbers on Spartan tunes.
My 560tq I typed here is a typo--it should be approx 760.
Old Oct 10, 2007 | 08:41 PM
dfuser's Avatar
dfuser
I guess I should have the read the complete post first. I am not claiming that the HP and Tq number showing on the spikes are what the combo was capable of doing. The Module is intended to be used only during the SLED pulls to adjust the duty cycle on demand.
The accurate numbers are as stated: 440hp and 760 tq. The truck will have a regulated system installed and a new BTS tranny. We will then redo the dyno and make more tweaking.
My appologies for not reading what was mentioned earlier.
Old Oct 10, 2007 | 08:46 PM
blackhat620
You may want to add this little fact to your website, since it says this module is safe with all stock trucks and Cruise Control (don't think i need cc at the sled pull) just add gauges and go!
"Steroid Power Module with Dual Adjustable *****
Adds up to 85HP-150ft lbs of torque! (Stock Truck-No Chip)
Increases oil pressure to injectors.
Quick install! Now works with Cruise Control.
Fully stackable with other chips!
We HIGHLY reccomend the use of gauges with this modification as this can cause high EGT levels when turned up.
For all 6.0L Powerstrokes 2003.25 - Up"
http://www.dfuser.com/mfg/powerstrok...erformance.php
Old Oct 10, 2007 | 08:47 PM
  #28
SpartanDieselTech
Former Vendor
Then why is "MAX 472.5 HP" plastered across the top of the dyno sheet?
Shift spikes are not even valid when measuring "MAX" Hp. IMO, this is simply intentionally misleading.
Old Oct 10, 2007 | 08:49 PM
  #29
dfuser's Avatar
dfuser
That is beacuse the Dyno computer spitted that info on the sheet. I'll have to get that doctored to show the actual numbers.
Old Oct 10, 2007 | 08:50 PM
  #30
SpartanDieselTech
Former Vendor
Yeah, you might want to do that.
