overhead trip computer
Old Oct 9, 2007 | 01:44 PM
totavikid's Avatar
totavikid
I have a 2000 PS Dually and just had my overhead trip computer stop displaying any kind of read out. Has anyone experienced this and does it have a fuse or is it just wired into the vehicle monitoring systems somehow?
Old Oct 9, 2007 | 01:54 PM
HKusp's Avatar
HKusp
If you do a search about this there are a lot of posts on it. i don't know about the fuse, but from what I have read there are a few resistors that usually come loose. If you pull the computer from the roof. There will be one or more of them loose so be careful. All you have to do is re-solder them. One guy actually used super glue and hasn't had any issues.
Old Oct 9, 2007 | 02:03 PM
totavikid's Avatar
totavikid
Thanks and I will check on that, just one more question, How do you get the console loose from it's position?
Old Oct 9, 2007 | 03:51 PM
dcara's Avatar
dcara
I'd like to know more about your overhead trip comp. Is it tied into the PCM and does it calculate instantaneous mpg? Is it post market? If so, where di you get it.
I've been thinking of a 3 gauge set over the mirror for outside temp, barometric pressure, and instantenous mpg.
Old Oct 9, 2007 | 03:56 PM
totavikid's Avatar
totavikid
The trip computer is OEM from the factory, most trucks I've been in have them, so it's not somethng I added. It must be tied into a variety of sensors as it senses temp, mpg, distance, fuel left and direction. Don't know anymore than that.
Old Oct 9, 2007 | 06:21 PM
HKusp's Avatar
HKusp
I'm not sure. I'll look and see if i can find it. Be right back.
Old Oct 9, 2007 | 06:24 PM
HKusp's Avatar
HKusp
Here you go. It should explain everything you need to know. Meischa seems to know his/her stuff.
https://www.ford-trucks.com/forums/s...26&postcount=4
Old Oct 9, 2007 | 06:34 PM
zx250's Avatar
zx250
Of the next Riffraff East
Yep, that's the one I used. Be sure and check his gallery, he has some great pictures showing the entire job.
Old Oct 9, 2007 | 07:03 PM
Chance_Thomas's Avatar
Chance_Thomas
I fixed mine with superglue. Yep it's still working with no problems.
Old Oct 9, 2007 | 07:42 PM
zx250's Avatar
zx250
I fixed mine with superglue the first time. Lasted over a year. Had to do it again, this time I did the solder thing and hope that will be the last.
Old Nov 1, 2007 | 02:50 PM
99f250d4's Avatar
99f250d4
Miesch's Diagnosis was right on! I took my overhad trip computer out today, one of the 620 chips had fallen off and another was hanging verticaly. A little solder and it works now. The display was a little dim at first, but, got brighter the longer it was on.
Great fix!
99' F-250 SD 7.3 Crew 4x4
Old Nov 1, 2007 | 03:42 PM
HKusp's Avatar
HKusp
Glad to know it worked out.
Welcome to FTE 99.
Old Nov 1, 2007 | 04:08 PM
totavikid's Avatar
totavikid
I inspected my unit and did not find anything out of place. went to the salvage yard and got another. plugged it in, now I know where I'm going. thanks all
thefnswits
Sep 21, 2008 03:28 AM
shadowdd
Sep 29, 2007 10:44 AM
GrassHopper2
Jan 26, 2006 07:09 PM
xp8103
Nov 13, 2005 03:26 PM
chefbill
Nov 12, 2001 02:28 PM
